I simply disabled win updates, coz last time it updated it wiped the linux boot partition on another drive and put there its own boot partition.
Guess what tho, because it was on a different drive it couldn’t fucking boot.
Had to use win7 install CD, drop to cmd and using their shitty tools make a new boot partition where it was before that, and then using Arch Live USB create /boot for Arch. WTF.
Peeker is very loud and slow in the air his primary fire is a nailgun.
I try to keep a good distance and rail gun the peeker to death from range
If I’m cornered by a strogg and they use peeker I know the fight is over, so I am prepared to either kill it quick with reaction or give up.
If you play a fast character, I would try to use any movement abilities to get out of the range to make it harder for the strogg to shoot you or dive bomb you.
I’m glad in the recent patch they added a cool down so peeker can’t instantly crash and explode upon deployment.
Yes it was me I was trooper #1157. I have been promoted to projectile specialist, but we troopers were given orders to make non-lethal shots in an attempt to follow rebels
