It depends what you are doing. For gaming, this method gives you higher frame rate. Also Windows sucks when you expose complicated underlying hardware.
hm, I have an TR 2920x, 12 Cores two NUMA nodes, and got my best results with a NUMA aware configuration.
There is a problem with CPUs that do not have all cores enabled, the 3 level is not correct. I haven’t tested this for a long time, maybe it works now without special config, but with my CPU I had to configure it that way
With this configuration I have about the same CPU performance as a 2700X sometimes even considerably better, in e.g. CPU PhotoWorxx is better than a 12900k, but the AES performance is bad.
But I will test your recommendation, let’s see if it works better with my CPU too.
Threadripper is another beast. NUMA aware configuration probably makes sense.
For 7900x/7950x, I don’t think there is much penalty to switch context between 2 CCDs.
I just came across a thread that’s the most comprehensive I’ve seen on the subject that I think many would find helpful as it clarifies multiple aspects of a very complicated topic.
Note that it’s targeted toward proxmox. The biggest thing to know with proxmox is that it typically stores it’s vm/qemu options in a simplified format in a .conf file, rather than XML.
Edit: Unless you mean some additional posts he added recently, I don’t have those yet, we’ll have to wait a bit. The Proxmox forums are notorious for having overactive automod scripts. See 1 and 2
