Qemu unexpected closed after motherboard exchange
Hello all,
I have the following problem:
two days ago my motherboard (MSI Tomahawk) died and I replaced it with a MSI Tomahawk MAX. After the installation I enabled my virtualization and iommu in the BIOS. Now I want to start my Windows 10VM again, but I get the following error message:
Error when starting the domain: Internal error:
qemu unexpectedly closed the monitor: 2020-12-22T21:01:11.505054Z qemu-system-x86_64: warning: This feature depends on other features that were not requested: CPUID.8000000AH:EDX.nrip-save [bit 3]
2020-12-22T21:01:11.505458Z qemu-system-x86_64: warning: This feature depends on other features that were not requested: CPUID.8000000AH:EDX.npt [bit 0]
2020-12-22T21:01:11.505469Z qemu-system-x86_64: warning: This feature depends on other features that were not requested: CPUID.8000000AH:EDX.nrip-save [bit 3]
2020-12-22T21:01:14.923163Z qemu-system-x86_64: -device vfio-pci,host=0000:28:00.0,id=hostdev2,bus=pci.4,addr=0x0: Failed to mmap 0000:28:00.0 BAR 0. Performance may be slow
2020-12-22T21:01:14.943505Z qemu-system-x86_64: -device vfio-pci,host=0000:2a:00.3,id=hostdev4,bus=pci.8,addr=0x0: vfio 0000:2a:00.3: group 5 is not viable
Please ensure all devices within the iommu_group are bound to their vfio bus driver.
Traceback (most recent call last):
  File "/usr/share/virt-manager/virtManager/asyncjob.py", line 65, in cb_wrapper
    callback(asyncjob, *args, **kwargs)
  File "/usr/share/virt-manager/virtManager/asyncjob.py", line 101, in tmpcb
    callback(*args, **kwargs)
  File "/usr/share/virt-manager/virtManager/object/libvirtobject.py", line 57, in newfn
    ret = fn(self, *args, **kwargs)
  File "/usr/share/virt-manager/virtManager/object/domain.py", line 1330, in startup
    self._backend.create()
  File "/usr/lib/python3.8/site-packages/libvirt.py", line 1234, in create
    if ret == -1: raise libvirtError ('virDomainCreate() failed', dom=self)
libvirt.libvirtError: Interner Fehler: qemu unexpectedly closed the monitor: 2020-12-22T21:01:11.505054Z qemu-system-x86_64: warning: This feature depends on other features that were not requested: CPUID.8000000AH:EDX.nrip-save [bit 3]
this is strange, the MAX Version of this motherboard is almost the same. shouldn’t that woord like before?
my system:
OS: Manjaro Linux x86_64
Host: MS-7C02 1.0
Kernel: 5.9.11-3-MANJARO
Uptime: 21 mins
Packages: 2085 (pacman), 3 (snap)
Shell: bash 5.0.18
Resolution: 1920x1080, 1920x1080, 1920x1080
DE: Cinnamon
WM: Mutter (Muffin)
WM Theme: Mint-Y-Dark-Teal (Mint-Y-Dark)
Theme: Mint-Y-Dark-Teal [GTK2/3]
Icons: Papirus-Dark-Maia [GTK2/3]
Terminal: tilix
CPU: AMD Ryzen 5 2600X (12) @ 4.006GHz
GPU: AMD ATI Radeon RX 5600 OEM/5600 XT / 5700/5700 XT
GPU: NVIDIA GeForce RTX 2080 Rev. A
Memory: 6016MiB / 32036MiB
best regards
D1Ck3n
lol, i solved it myself :smiley:
i checked iommu group 5 and this was my old audio connection i bridged :smiley:
IOMMU Group 5:
	00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
	00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B [1022:1454]
	2a:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Zeppelin/Renoir PCIe Dummy Function [1022:1455]
	2a:00.2 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
	2a:00.3 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) HD Audio Controller [1022:1457]
