After I slightly modified the VM configuration, everything was ready to use.
PS: And it seems to be due to the sound card, I need to use alsamixer to adjust the sound card volume.
Sorry for necroing an old thread and Iāll create a new one if applicable but Iāve been trying to get JACK w/ Pipewire-Jack working on an Windows 11 VM on a Fedora 36 host but Iāve not been able to without setting SELinux to permissive (and unlike with the looking-glass shim Iāve not been able to do something with audit2allow). I was wondering if anyone here has an idea on what label I could set to get it to comply as all the instructions I can find are for AppArmor (including in this thread).
The relevant section of my libvirt xml is give or take
Iāve found a solution, but itās neither pretty nor ideal but itās better than setting SELinux to permissive globally - disabling security confinement for QEMU specifically in /etc/libvirt/qemu.conf i.e āsecurity_default_confined = 0ā. It should be fine enough with a single VM but yeah, not ideal. Either way, it works (at least for me).
Iāve been trying to get Looking Glass working but the host just doesnāt seem to work (unless Iām doing something wrong). This is on a Windows 11 VM btw and the passthrough portion works fine outside of audio (I still get crackling even with Pipewire Latency tweaking) so I hope switching to Bleeding Edge would help solve that issue too. Speaking of which, do all I have to do to get the host working is install it and then run it? Cos thatās all Iāve been doing so far and well
[I] 12091927196 main.c:1123 | lg_run | ================================================================================
[I] 12091927208 main.c:1124 | lg_run | The host application seems to not be running
[I] 12091927209 main.c:1125 | lg_run | Waiting for the host application to startā¦
[I] 12092564049 main.c:1130 | lg_run | ================================================================================
[I] 12092564064 main.c:1131 | lg_run | Please check the host application is running and is the correct version
[I] 12092564068 main.c:1132 | lg_run | Check the host log in your guest at %ProgramData%\Looking Glass (host)\looking-glass-host.txt
I donāt even have a log to see there, and itās the correct version for both (B5.0.1).
Hello!
Im new to virtual machines.
Iām very interested in running garageband in a vm in my system. Which i have achieved by following this tutorial:
github /foxlet/macOS-Simple-KVM
But it like to be able to connect it to jack.
The thing is i dont know where to enter the arguments you give in your post. Would you give me a hand? thank you.
I created this SELinux policy to get around the issue. It should only allow what is required as I only fed audit2allow the block events that happen when my VM started.
module libvirt-jack-socket 1.0;
require {
type svirt_t;
type user_tmp_t;
type unconfined_t;
type system_dbusd_t;
type system_dbusd_var_run_t;
class sock_file write;
class unix_stream_socket connectto;
#============= svirt_t ==============
allow svirt_t system_dbusd_var_run_t:sock_file write;
allow svirt_t user_tmp_t:sock_file write;
allow svirt_t system_dbusd_t:unix_stream_socket connectto;
allow svirt_t unconfined_t:unix_stream_socket connectto;
