QEMU-KVM Installation Issue in OpenSUSE
Just trying out OpenSUSE in a Vbox VM (windows 8.1 host).
I installed Qemu-KVM via terminal and it installed ok (as far as I know), but now I can't find it anywhere, even if I do a search and can't even start it from terminal.
Am I doing something wrong or does it not work inside a VM?
This is what I get:
mike@linux-ilmq:~> qemu-kvm
Could not access KVM kernel module: No such file or directory
failed to initialize KVM: No such file or directory
mike@linux-ilmq:~>
Thanks.
There'a probably not much point worrying about it, I would be amazed if you could nest KVM hosted VM's inside a Virtual Box VM. However I am not sure if that is the reason for the error you are seeing, someone more knowledgeable on Linux and KVM will be able to tell you.
There are loose definitions for Type 1 & Type 2 HyperVisors. Type 1 generally means the hypervisor is running directly against the hardware, Type 2 means it is running against host OS. KVM, ESXi and Hyper-V are all Type 1, Virtual Box and VMware Workstation are Type 2.
Nesting Type 2 hypervisors inside VM's hosted on Type 1 hypervisors is sometimes possible, i.e. I have heard about people running VirtualBox inside a VM hosted on VMware ESXi. Doing it the other way round unlikely to be possible.
If you wanna run a qemu vm, by typing in "man qemu", you'll see that it says
SYNOPSIS
       usage: qemu-system-i386 [options] [disk_image]
KVM requires VT-x or equivalent on AMD but I don't think Virtuabox can allow guests to access VT-x/other
Indeed, verify you have support for it running "lscpu"
Virtualization:        VT-x
silly as it sounds, 1 are you using KVM kernels? 2 are you logged in as one?
You might find some useful info in here: https://forums.virtualbox.org/viewtopic.php?f=1&t=20589
I'm running an i5-4570 which does have VT-x enabled.
I wasn't planing on actually creating a VM within the Linux VM - I only wanted to install this program to explore the options/features. But I can understand if it doesn't work at all because I'm installing it in a Virtualbox VM to begin with.
Thanks for the tips.
I don't understand either of those questions... lol.
Care to explain? :)
