Q | remarks on server parts list
Greetings,
I am looking for any remarks regarding the server specks bellow:
Parts Specks
Case SST-CS381
Mobo X570D4U-2L2T
CPU AMD Ryzen 5 5600G
Cooler stock
RAM 2×Micron 32GB DDR4 Modul ECC RAM (MTA18ASF4G72AZ-3G2R)
PSU Seasonic FOCUS-SPX-750
GPU got it (vapor-x hd 4890)
HDD Seagate IronWolf Pro ST18000NE000 18TB
Seagate IronWolf Pro ST22000NT001 22TB
Seagate barracuda 500GB
SSD Samsung 870 EVO SSD pogon, 1 TB
planned another SSD
ups Socomec (NETYS PR) PR MT 2000VA
Regarding the specks:
GPU:
for transcoding and for playing with GPU Passthrough/might upgrade in the future if needed
RAM:
it’s not listed under verified RAM on the official website but I hope It will be good
PSU:
Hope it will be enough if in the future I have, let’s say 12 drives and a modern midrange GPU
For the following:
  • NAS and Nextcloud (primary)
  • Virtualization or VM’s
  • In the future if possible server rendering
Thank you kindly
Did they add ECC support on the APUs?
Yeah you need the pro line of APUs
aaa good to know thank you any remarks on the PSU situation?
The G has no ECC support the Pro does.
Can always go hba + disk shelf later if you put grow the psu but I doubt you will
Thank you all
Ive always heard this recommendation. How does this work, exactly? You plug a PCIe that spits a (proprietary?) cord out the back that connects to the shelf that has drive caddies and controllers? or does it work through the LAN cable?
The HBA is just a PCIE card that can talk to multiple drives on one cable that cable connects to another device that can have a lot of drives connecting to it. There is a limitation of bandwith for the card (Pcie speed) and the number of connections it has to the shelf. Only really an issue with SSD shelfs and for home labs its not really an issue.
Here is a talk about building your own. But they make COTS shelfs you can get.
