Hey guys I am messing with Python and I am wondering why the super() keyword isnt working in this short script or how to use the super() word?
`class Person:
def __init__(self,agef,namef):
self.age=agef
self.name=namef
def getAge(self):
return self.age
def setAge(self,num):
self.age=num
class Bob(Person):
super(Bob,self).__init__(agef,namef)
#Person.__init__(self,agef,namef)
p = Bob(15,"bob",92)
p.setAge(29)
print p.getAge()
Hi Chiefshane,
I don't deal with classes a lot, so might have to dig deeper. However, I think super is only used to override the child class, in case you have the same method name in the parent and child. So in case of confusion, you say super and the parent's method is used.
This code works for me. The moment class Bob is intialized it has all the methods of the parent, "person", so there is no need to use super in your example.
class Person:
self.age=agef
self.name=namef
def getAge(self):
return self.age
self.age=num
class Bob(Person):
self.age=agef
self.name=namef
# I think super is only used to override stuff
p = Bob(15,"bob")
p.setAge(29)
print p.getAge()
More information is available here, and here.
- Your indentations are all screwed up.
- You call the bob constructor incorrectly, it takes 2 variables not 3.
- Person needs to be defined as an object (i.e. class Person(object): )
In [4]: p = Bob(92, "bob")
In [5]: p.getAge()
Out[5]: 92
In [6]: p.setAge(29)
In [6]: p.getAge()
Out[6]: 29
self.age=agef
self.name=namef
def getAge(self):
return self.age
self.age=num
class Bob(Person):
