I’m sorry if there is a stupid answer to this question, but I don’t like how bright the “has power” LED on my GPU is, especially at night. I want to suppress that by putting electrical tape on the LED; is that a good idea or is there a better solution?
Yes, I have been turning off the power supply every night for 2.5 years, don’t want to keep doing that.
Depending uppn the GPU, you may be able to turn the light off in software. Most Nvidia GPUs with a light can be switched off in GeForce Experience. Not sure on AMD, no experience here.
I had to do this for an older Sapphire card. Electrical tape works fine. Non conductive and non damaging. Any residue left behind when you remove it can be taken care of with some rubbing alcohol.
