I did a Prime95 test on my Xeon E3-1230v3 and I was hitting around 65 degrees C with a push configuration on my H50, 2 intake fans in the front and 1 bottom, 2 exhaust fans on top + the radiator fan in the rear.
I added an extra fan to the radiator to make it push/pull and switched the two top fans to intakes. I now have 5 intake fans and just the radiator and two HD 7970's as exhausts. My temperatures dropped by about 6 degrees C consistently after a decent length test with both configurations.
I always thought that push/pull didn't do that much and that you shouldn't have a disproportionate amount of intake/exhaust fans. Thoughts anyone?
