My top 140 mm exhaust fan on my cm scout is making a "rackety" sound.
I cleaned out the dust tightened the screws/loosen them...still the sound is there.
It's driving me insane... Any body got any fixes?
I can't deal with it anymore...
help a desperate soul...
buy a new fan, lol one of the blades on my 140mm broke off and im using it with 1 blade missing
If you want a silent casefan, Noctua is the deal.
DOOM
March 22, 2010, 12:08am
4
Put some WD-40 on the ball bearings.
Yah but $30 for a fan thats brown and beige flesh color is not my thing.
wd-40 champ, use it. if you want a new fan, just get a shitty one.
This had happened to me too for the rear fan. The propeller was very loose like you can almost pull it out.
Where do i actually put the wd 40?
Between the centre of the rotor blades and the frame, there’s a motor inside. Spray on it.
Akamu
March 22, 2010, 11:09am
10
Lian Li Anti-Vibration Screws stopped the noise: [color=#ffff00](They come in all black also)[/color]
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=60_236&products_id=26581
Its not vibration.
I completely unscrewed the fan and the sound was there. It’s the bearing that’s making the sound.
I was told not to use WD-40 but Olive oil.
Akamu
March 22, 2010, 8:35pm
12
I had that annoying sound in the bearing and those screws shut that shit up. If that olive oil doesn’t work, buy a new fan.
Yah, I’m going to try some Olive oil…
The anti vibration is cool and but for $10 + shipping I might as well buy a new fan.
I was told to purchase ball bearing and not sleeve bearing.
Have any suggestions?
DOOM
March 22, 2010, 9:52pm
15
I’m telling you man, pull out the propeller and spray your bearings down with some WD-40, or olive oil, or baby oil( pretty much any kind of lubricant, which i know you have )
If it persists buy new bearings or buy a new fan or duct tape a vacuum to your computer.
HAHAHA yah…
I’m going to try some olive oil and see how that goes. If not than new fan it is…
I been wanting some red led fans…
HAHAHA yah…
Wowzers, GameShit is going out of control for you there Pathogen
Mods cleaned it up…
Yah lol
