Public VPN's and IP Abuse scores (how to avoid this?)
Hi everyone,
So let me preface this with that I am a bit of a privacy absolutist. I believe that any level of tracking what so ever is unacceptable and intolerable, and I attempt to avoid it at any cost.
To that point all of my traffic is routed at the router level to a trusted no-log VPN service (Mullvad), all of my browsers are LibreWolf (or Mullvad browser when that fails me), I don’t use any cloud services, don’t use any remotely hosted AI, and host my own SearXNG server in order to avoid/minimize search tracking.
This is all good and well, but a problem that continually bites me in the ass is that the Mullvad - while an awesome VPN provider - can’t avoid the economics of scarcity when it comes to IPV4 addresses. My exit point is used by lots of their customers. Some of these customers are up to no good, and legitimately get reported for abuse. In other cases, many sites assume the worse when they see multiple users originating from the same IP address, and assumes that means there is some sort of abuse, and automatically flags the IP address.
Either way, this means that my legitimate desire to remain as anonymous as possible as I navigate the internet is being falsely labeled as abuse and I am often blocked.
Today - for example - my SearXNG instance is useless, as suddenly out of nowhere, I am being given errors on all of the upstream search engines.
…and checking the mullvad external IP reputation on abuseipdb.com confirms that the address now has an abuse rating of 51%, which is probably the cause.
At the same time I have been a very late adopter of IPV6. I simply have not built up the level of trust necessary to embrace it yet. Something about devices on my local network having globally unique external addresses just makes me really queasy.
I am used to thinking as my local LAN as just that, a local network. It may just happen to be connected to the greater internet via a gateway, but it is not a part of the internet, and I can’t help but feel like forcing my devices to have globally identifiable IP addresses is the outside world trying to shape my LAN, which I really don’t like.
But this annoyance with IP reputation is really starting to become quite bad, so I am looking for ways to improve it.
Which begs the question. Does anyone know how VPN providers like Mullvad handle Wireguard tunneling for IPV6 users? Do they do it the same (bad) way as with IPV4 and use NAT66 to give all users of an exit point the same external IP address, or do they take advantage of the more plentiful IPV6 addressing to provide more exit IP addresses for the same server?
If it is the latter, it might actually help avoid the bad IP reputation problem as it should both reduce the chances of false positives (due to fewer people using the same IP) and should help reduce the risk of sharing the same public address with someone who is up to no good.
Thoughts? Will switching to IPV6 for VPN purposes help with this problem?
Appreciate any input.
I believe ProtonVPN is in the process of enabling IPV6 across their whole stack and they will let you generate a wireguard conf file… But you’d likely run into the same above scenario. Best option may be to get a VPS(cheapes one you can find) slap debian/ubuntu on it and install wireguard server on there.
I don’t think so… but wouldn’t hurt trying. You’ll likely be playing roulette as some providers just might treat all IPV6 addresses as having a “low” reputation.
Hmm.
If I were to do that, all of my traffic would be exiting on the same IP address, and as such would be more identifiable.
Yeah, the hope is that instead of one VPN server using one IPV4 address and tunneling everything out from that IPV4 address, that the VPN provider would use a full /56 IPV6 subnet like an IPS might assign to a household, for the server, and as such they would have 2^72 ip addresses (or 4,722,366,482,869,645,213,696 addresses) to spread the users connected to that server across.
If they were to take this approach, you would be much less likely to be sharing IP addresses with anyone else, and thus are less likely to be caught up in false reputation flagging.
I guess they could do that, but just about everything is moving to IPV6 these days. It has taken much longer than anyone thought it would, but - for instance - just about all mobile traffic is IPV6 these days, and IPV6 is slowly becoming the default with more and more ISP’s.
And mobile is the vast majority of internet traffic these days, so they would be treating most of their potential users as “low reputation”.
The bigger risk is that they wind up flagging entire subnets instead of individual addresses, and we wind up having the same problem as we have with IPV4.
This is a common problem with such solutions. I run Pi-hole + unbound and am frequently blocked by some e-commerce sites because they can’t tell where I’m located by DNS endpoint so they assume I’m a threat. Comes with the territory.
Hmm, the abuse site is interesting, will check it out.
For now, do you cycle the endpoint from those available, and see if any result in a better score?
That’s what I did on mullvad, if blocked by a site/service
I’ve not looked at ipv6, but presume any blocking, would simply be a higher level
Like, instead of blocking /24 or /20 or /16 subnets, they might block /56 or /40 or whatever equivalent in ipv6 world is?
Or, might it be a chicken-and-egg game, where the spammers have not yet gotten the VPS endpoints blocked yet and it will come later?
A VPS is the same deal.
The blocks of IPv4 addresses they have, are limited and recycled.
A bunch if VPS providers, have had bad actors rent their services and abuse them, causing a lot of them to be restricted as well.
Not all, but it is roulette
(I also think some VPN’s, use VPS’s for endpoints, but haven’t done the research to prove it)
Well, Mullvad comes right out and labels which of their servers are rented and which are owned.
Most of them are rented from other providers. On their server browser, of all of the servers in the U.S. they list 210 servers as rented, and only 6 of them as owned.
That said, I don’t know if they are VPS:es or full servers. I don’t know how many people generally use a server at a time, but I have personally pushed almost a gigabit full duplex through their servers, and their server browser lists most of them as being 10Gbit so if they are VPS:es those VPS:es have to have substantial bandwidth if they are going to support both Mullvad and other users at the same time, as well as enough CPU power to keep up with Wireguard at that bandwidth.
Yeah, I’m in the Boston area and they have four servers here (though one of them has been offline for several months)
After running into this problem yesterday, I rotated servers and one of the other three wound up working.
Amusingly enough it had a higher abuse score than the one I rotated away from, but this is probably not surprising as abuseipdb.com is only one of many IP reputation databases, and they likely differ in their reports depending on who is doing the reporting.
My performance to the New York City area servers is generally very similar from both a bandwidth and latency perspective as the local Boston ones though, and there are 25 of those, so I will probably always have a bunch of options to choose from and should be able to fins at least one that works…
But this is time consuming and annoying. I wonder if I can script it somehow to try another server once one is getting bad.
I sent an email to Mullvads customer support to ask them how they handle things on IPV6, if it is all routed to a single IP address per server, or if they take advantage of a /56 block per server and distribute IP’s, but based on the response it sounded as either the support person didn’t know enough to understand my question, or they were being intentionally vague in order to not give out information.
I suppose I could test with a few different devices, connect to the same server via IPV6 and check if I ever get a different IP address or if it is always the same one, but that wouldn’t catch if they route everyone through the same IP or if they route to a different IP on a per-account basis.
As a complete aside, I still think it is really cool that one can get single digit pings through a VPN these days:
# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=116 time=5.94 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=116 time=6.84 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=116 time=9.1 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=116 time=6.37 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=116 time=6.56 ms
64 bytes from 8.8.8.8: icmp_seq=6 ttl=116 time=8.7 ms
64 bytes from 8.8.8.8: icmp_seq=7 ttl=116 time=6.04 ms
64 bytes from 8.8.8.8: icmp_seq=8 ttl=116 time=7.2 ms
64 bytes from 8.8.8.8: icmp_seq=9 ttl=116 time=5.59 ms
64 bytes from 8.8.8.8: icmp_seq=10 ttl=116 time=6.31 ms
64 bytes from 8.8.8.8: icmp_seq=11 ttl=116 time=6.39 ms
64 bytes from 8.8.8.8: icmp_seq=12 ttl=116 time=6.26 ms
64 bytes from 8.8.8.8: icmp_seq=13 ttl=116 time=6.79 ms
64 bytes from 8.8.8.8: icmp_seq=14 ttl=116 time=7.1 ms
64 bytes from 8.8.8.8: icmp_seq=15 ttl=116 time=6.80 ms
64 bytes from 8.8.8.8: icmp_seq=16 ttl=116 time=8.1 ms
64 bytes from 8.8.8.8: icmp_seq=17 ttl=116 time=6.57 ms
64 bytes from 8.8.8.8: icmp_seq=18 ttl=116 time=7.3 ms
64 bytes from 8.8.8.8: icmp_seq=19 ttl=116 time=5.45 ms
^C
--- 8.8.8.8 ping statistics ---
19 packets transmitted, 19 received, 0% packet loss, time 18024ms
rtt min/avg/max/mdev = 5.450/6.811/9.100/0.963 ms
I was very happy with Mullvad’s service, and affordable price.
It even worked for whole house VPN, and was good enough to game one, as well as download through steam etc.
No complaints at all.
That’s how I use it. I have WireGuard set up on my custom OPNSense router and it routes all external traffic via Mullvad.
The only issue I have is that some webpages have started blocking my access, which is really annoying. Most of the time my philosophy is that if a business wants me to compromise my privacy in order to interact with them, then that is not a business I want to have anything to do with anyway, but occasionally it winds up being something unavoidable, and then it sucks.
Something that just hit me. Could you route traffic through a proxy to attempt to bypass the blocks?
A quick search and I found this from mullvad: Different entry/exit node using WireGuard and SOCKS5 proxy
Not a network specialist and it’s been a while since I’ve had to admin any network infra besides my unifi router, but I’m pretty sure you can even set certain domains to go through proxy with rules on a router or maybe browser add-in on firefox/chrome? Swear there was an open source tool for that…
Thanks for the idea. Looking at what they are proposing it essentially looks like you wind up entering through one mullvad server and exiting through another.
This definitely has some applications. Suggestions they have are for greater security against monitoring techniques that can compromise single hops, and circumventing bad peering that can result in poor performance, but there is no saying that the exit IP on the second server is any better than it is on the first, so I don’t think it is the solution I am looking for.
Proxy will use is a different IP. If I’m understanding correctly It’s pretty much like using a VPN with the encryption.
In theory you could proxy from someone else as well. But not sure who’s trustworthy in that area.
Found the extension I was thinking of as well: GitHub - foxyproxy/browser-extension: Version 8 and above. Browser extension source code for Firefox, Chrome, and other Chromium-based browsers · GitHub
I replied back to Mullvads response requesting more details and got the following which at least sounds promising:
(I extracted this bit from the response)
So it looks like moving to IPV6 at least might have a small chance of success, provided the IP abuse databases don’t flag entire subnet ranges on IPV6 when they discover unwanted activity on just one, but at least then maybe the problem of multiple users from the same IP causing false positives might be reduced.
It is at least worth a try.
It is funny that all of these years later I finally have a reason to try IPV6.
to avoid tracking use a dedicated no logs vpn, like shieldway vpn. seriously there is nothing simpler than that!
The issue here is not necessarily avoiding tracking, but rather doing so while also not getting an exit point IP that has been flagged for abuse, and thus results in many sites not functioning.
Though I would also argue it is not quite that simple. Tracking by origin IP (or ISP embedded fingerprints in origin IP packets) is only one concern. Browser fingerprinting is also pretty huge, and much more difficult to defeat, unless you are on a very generic system so it blends in with everyone else, and as enthusiasts we rarely have very generic systems.
I’m not familiar with Shieldway, but I will read up on them. It will be good to have another decent vendor. I hold Mullvad in pretty high regard. I used to also trust Proton more, but I have started hearing some pretty alarming things about what the Proton CEO says in private questioning his dedication to true privacy and embracing AI slop.
