Okay, I had one more post that is a genuine question. I'm of course so stupid that I completely forgot to get a PSU for my desktop build. I found a reasonable PSU with semi-modular cables and 720 watt output. Its around 115$ (Cooler Master Silent Pro M2 - 720W Power Supply with 80 PLUS Bronze Certification and Semi-Modular Cables) but it the wattage the only thing to take into account? Do I need specific voltage too or something else I'm completely missing? Please let me know if I'm going to completely screw up if I use this or if it sounds good. I can provide the other components if anyone needs/wants to know what they are to add any additional help. Thanks in advance! This community has really upped my ability and confidence in building and re-building since I joined the site and even since I started watching the YouTube channel.
http://www.amazon.com/EVGA-SuperNOVA-NEX750G-Certified-120-PG-0750-GR/dp/B009YC3EAI/ref=sr_1_3?ie=UTF8&qid=1385075717&sr=8-3&keywords=750w+psu Cheaper and more efficient PSU. Also comes with a 10 year warranty and is fully modular.
You don't have to really worry about anything other then wattage when looking for a PSU. But just never buy a stupidly cheap one which will short your whole system because of bad design or tacky components.
Amps on the 12 V line are what you want to look at. If you want more info look at my other posts on PSUs.
That's a much nicer PSU than the one I found, I think you just saved me from a 120 dollar mistake, thanks! I'll be ordering it soon and put the build up on here.
