PSU NOISE ISSUE, Please help
https://www.youtube.com/watch?v=eu0uPM41JGs&hd=1
This noise has started all of sodden. I have overclocked my Pc with OC Genie wich is comes in my bios.
  Specs:
Cpu: Intel I-4670k OC @ 4.00 ghz
Gpu: Gtx 770 not OC'd
PSU: Thermal Take 650w Bronze PowerSupply
Thanks, im wondering if there is a way to fix this problem without having to return my PSU.
cant tell if it's the fan or maybe the electric components are going out. unless you are experienced in electrical engineering i'd suggest you return the PSU and get a replacement.
Im 13, and im expiernced a BIT in computers. I got this Pc pre-built and the WHOLE Pc is under warranty. But I had to ship it around 2 months ago because of the graphics card, and it took around a month for it to get back. And IF possible, I would like to not have to ship it.
well i would not continue to use the PSU because it sounds broke and if it's broke that means it can potential break other stuff in the computer. also messing with the psu is pretty freaking dangerous, even after you unplug it there can still be a charge in a random capacitor that could electrocute you if you go and open it up and messing with it.
I wont open it, could it be me OC'ing it and it not being able to supply power or something?
This is the Hardware subforum. "These topics are from the old site. Do not post new topics in this forum."  and it says it there.
Link to picture if you can't see https://docs.google.com/file/d/0ByycBNIVqin8Ym1IbDA5TEJNckE/edit
Please delete this and repost in the Other Hardware subforum right below hardware.
Sounds like a wire is hitting the fan... that or there's some dangerous electrical discharge roaring through that PSU.
I turned of my OC Genie and I haven't heard the sound since. Ill keep you posted
For the love of all that is holy, please stop posting in the Hardware subform!
Must be a really crappy PSU if that basic overclocking put too much stress on it, causing the fan to ramp up and make that noise, or causing the components to make that noise (it shouldn't ever make that noise, even at 105 C 100% load sustained).
