Im connecting a Rog Zenith Extreme Alpha to my PSU and the manual shows the 24 pins + 2 x 8 pins need to be connected. Do I use a 6 + 2 pin PCI-E connector for the 8 pins? It just seems odd since the 6 pin head is separate from the 2 pin plastic connector.
You dont need 2 8 pin for the CPU you can just use 1 it will be fine (you will be limited on power budget tho so dont OC it if its the big boy)
You dont want to use a PCIE power connecter to go to the CPU needs to be 4+4 , they are pinned out differently
Ok I didnt receive a 8 pin connctor with the PCU or the Motherboard.
The PSU will give you an 4+4 not an 8 pin solid connector generally (havent seen any that arent 4+4, not to say they dont exist)
What PSU do you have?
So the manual says to plug both in TR might draw more then the 1 8pin can demand, havent seen power numbers on those (never looked into it, I know main stream and 1st gen TR didnt need it)
So if you exceed that you might have issues with just 1 connector
http://www.playtool.com/pages/psuconnectors/connectors.html
Great source of info on connectors
So according to tweaktown
1 connector would work but 100% on the edge of whats safe, so prob best with 2 with literally any OC
Thermaltake Toughpower GF1 850W 80+ Gold SLI
I checked and it says its ATX rated for this motherboard
Ok it shows it comes with (2) 4 + 4 ATX 12v. Are those what I need?
Thanks!
Ok, Whats the “pemium version”?
Double check the link, the item is a really long description, wiht a lot of buzwords.
Sorry, I fired off before double checking.
#TooMuchMarketingFluff
The one I saw on Newegg might (maybe) have a couple of extra bit, not too sure
The one i saw said 2 4+4 as well
I only see 1 x 8 pin connection on the back of the PSU. Do I use the 10 pin and only the 8 corresponding pins that match?
The manual for the zenith extreme alpha shows that I need 2 x 8 pin
Look through the cables provided find the two that have 4+4 pin on the one end, Guessing one of the 4+4 pin has 2 8 pin connectors on the other end or 2 6 pins
The 10 pin connector does look odd, like it is supposed to connect to the 4+4, but the clip is in the wrong place for the 8pin connector. interresting
Ok I was looking at the picture on Thermaltakes website ****://www.thermaltakeusa.com/toughpower-gf1-850w-tt-premium-edition.html and it doesnt show 2 x 8 pin spots. Thanks for for image.
Should I go up to a 1000w? I can get the EVGA SuperNOVA 220-G3-1000-X1 and save the Thermaltake for another project. Not sure if the EVGA G3 would be better even in the 850 watts
AMD Threadripper 3970X 3.7 GHz 32-Core Processor
Noctua NH-U14S TR4-SP3 82.52 CFM CPU Cooler
Asus ROG ZENITH II EXTREME ALPHA EATX sTRX4 Motherboard
PNY Quadro RTX 4000 8 GB Video Card
you ideally want the load you computer is going to be at most of the time to be around 50% of PSU load (the most efficient part of most psus) so depend on how you are using the computer and future expansion.
