My build thus far is:
CPU: amd iix4 athlon 750k
GPU: sapphire r9 270
M'board: asrock fm2a75 pro 4
RAM: 8gb kingston hyper x
HDD: 1tb wd caviar blue
Cooler: Coolermaster hyper 212 evo
For the case I'm pretty much set on getting the corsair carbide 200r windowed, but the psu...
I want to oc and in the future I will add a second 270, so in terms of wattage what would you suggest? I was thinking along the lines of 750w as the fractal design integra r2 is only €6 more expensive than the corsair 600w where I shall be buying the parts ( dabs.ie ).
*Btw everything listed above the case I already have.
