PSU For my Build
I already have this http://www.newegg.com/Product/Product.aspx?Item=17-152-028&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=13#scrollFullInfo
I was wondering if thats enough to power my fx 4170 cpu and my 7870 gpu ??? Thanks in advance also the cpu power says 125 watt and the gpu 500 watt but ive heard you really dont need all that power !
The wattage will be enough, but I don't like Raidmax. They aren't that good. But you may be lucky
Dont buy Raidmax, it will fail you in so many ways.
I already have it D: so its what im going to have until i get more $$$
You say that now, but then you spend the time doing all the cable routing and a few weeks later you're just like "ah, fuck it" and end up getting nothing to replace it!  lol
