Hi guys I'm about to purchase the parts for my first gaming PC which you can see here. The final part I'm undecided on is the PSU as there may be a small incompatibility issue with Haswell CPU's. I was looking at this EVGA Supernova PSU and was wondering if anyone had used one of these and could vouch for them. If not could you please offer some suggestions? I have around £80 to spend on a PSU, but I don't want to overspend for the sake of it, I just want a good solid PSU.
Dude, there's no such thing as an incompatible Haswell PSU. The PSU I showed you is fine.
The problem is that some PSUs will not allow your computer to fall into a low power sleep mode. That doesn't mean that you cannot use it, and certain sleep modes are still applicable - but they are not low powered.
The sleeper states are turned off at the BIOS anyway. You actually have to go into the BIOS to turn them on.
Oh okay thanks Berserker. It's just that it's my first build and so when I hear there may be some kind of problem I immediately think it's the end of the world. I'm thinking that a little further down the line, 6 months-a year, I may want to upgrade to a R9 280X or something similar. Will the 550W be enough or should I play it safe and get the 650W?
