Are these psu worth damn.
The fact that I can't find any information on them is troubling. What will you be powering?
I was tempted to get one but couldnt find anything about the quality of them.
850w for only $60 sounds way to cheap to be 'good'
There are no reviews or information that I can find. Chances are, though, you don't need 850W. A quality PSU, like a Rosewill Capstone 550, can easily deliver upwards of 700W without breaking a sweat.
Ya not enough info on that product. Little scared of that myself. Thanks Brennan
I just considering future upgrading. And i really need to get a new psu now my is 5,
6 years old. I gonna end up with a saber or a crosshair and at least a pair 7950 at some point
A 7950 with an i5 (socket 755, right?) will do just fine on a 550W PSU.
8350 crosshair or saber board at least a pair of 7950
Oh, 7950 CF; that's closer to 650W.
Its more about the quality my pcs run 24/7 .What would you consider ideal for that kind of use?
650W; 750Wonly if you get a good deal.
ty
No problem :)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207023 Think i am going to go with this.
