PSU dead? (help me please)
Hi  guys how are you ?
Today i was listening to spotify while i was laying on my bed resting when suddenly i hear a computer crash with  a strange noise coming from the speakers.
Now if i turn on the computer , it boots and turns off in a loop.
what can i do to be certain of what component is responsible for this issue?
I´ve my pc for about almost year, these are the specs:
-Asrock z77 pro 4;   Intel i7 3770;  xfx hd radeon 7850;  psu corsair tx650;  2 HDD 2,5 TB;  4x4 gb ram
thank you very much.
Turn it the computer off completely. unplug it from the sockets then hold the power button for 10 seconds.
Open up the case and pull out all the ram. Then add just one module, plug the power back in and test if it turns on. if it does keep adding one and test it.
tried what you told, when i was turning the computer on with one module, it started to smell something burning and then i saw a little smoke coming from a little piece, the thing was incandescent:\  probably the board is dead.
http://imgur.com/fQ3s7EL  on that circle
bet you shat your pants XD
dude  i'm shitting my pants right now cause i need  my pc to do school work , i work with photoshop, zbrush,sketchup and now i'm fucked cause i don't have money to buy another motherboard.
i don't know if the warranty covers this type of damage.
the board could be shorted out, or a screw is causing short circuit, okay what to do.
take everything out of your case, lay the motherboard down on its box. reseat the cpu and cpu cooler, install one stick of ram. connect the monitor to the onboard video port, from the motherboard, connect the 24pin atx power connector, and the 8 or 4 pin cpu power connector, and fire it up outside the case, shorting the powerbutton pins for a second with a screw driver, "becarefull with this" and looks if it boots. if it boots you are lucky. iF it doesnt do anything then the board is dead.
i tried every component and it seems that the mobo is dead, cause even the psu is working.
I think this shit happened cause here in my street the electricity goes down a few times a month, and i'm still thinking about the ram if it caused anything to the board cause they are cheap hp ddr3  modules. I'm going to send my mobo to asrock from my local store  but i still have to wait an entire month to get a new one. Now i can't do my work.
