As the title says i bought a PSU and i need to know if its unsafe the sidewall of the psu is dented and i not sure if its safe. should i return it? thanks in advance
if it's a quality PSU and the build quality is good then it's just cosmetic. Some cheap PSUs get broken easily if you shake them.
If the fan is working properly and unobstructed then that is merely a scratch and nothing to worry about.
Oh ok, cool thanks
The model i got was a EVGA 500B, if that makes any difference
