PSU choice: XFX Core Edition PRO 850W vs XFX XXX Edition 850W vs something else?
Hi guys!
I'm looking to upgrade my rig over the next few weeks. After getting help here on choosing an ATX case, I need help again in deciding which power supply I'm going to get. Here's a list of things I'm looking for:
  • Supports 2 mid-range Nvidia GPUs (GTX 460 1GB and perhaps GTX 660TI/670)
    • 800W+ (or would 750W suffice?)
    • 4 x 6/8 pin PCIe
  • Preferably from Seasonic (since Logan and most of the Internet loves them)
  • Quiet
  • <$120 (in my case in Germany <€120)
So far I've found:
  • XFX Core Edition PRO 850W (P1-850S-NLB9)
  • XFX XXX Edition 850W (XPS-850W-BES/P1-850B-NLG9)
Both of them are a bit "older", i.e. they've both been released before 2012, does that make a difference for PSUs? And which one would you recommend out of those 2, or do you have another recommendation? Reviews online aren't making it clear to me which one is quieter under load.
Thanks for the help!
850W is fine if you want to do SLI should handle 680 or 7970 good single or in SLI
The age does not matter as long as they have an 80+ rating
if they have 80+ bronze rating its fine, XFS psu´s have seasonic  boards inside thats what logan told in one of his vids, so then the quality should be fine.
either/or. doesn't matter.
