PSU Calc
Anyone have something really reliable with many options?
Upgrading soon, if I could shave 50$ on a PSU it would be useful to something else.
  1. what country do you live in
  2. what parts do you have
  3. what is your budget for parts you need
Nvidia and Intel tend to have much lower TPDs (use less juice)
USA
Intel Core i5 3570K @ 3.40GHz 45 °C
8.00 GB Dual-Channel DDR3 @ 679MHz (9-9-9-24)
ASUSTeK COMPUTER INC. P8Z77-V LK (LGA1155)
NVIDIA GeForce GTX 660
1TB Western Digital WDC WD10EZEX-00RKKA0 (SATA)x2
And bout a 1k usd budget
Just rather not go overkill on PSU if I can use it somewhere else.
550-650 would be my guess depending on fans,usb devices and other stuff
stock 3570ks use 77w, the most powerful single GPU from nvidia uses 195w, you can SLI 2 660s on a 500w PSU
I highly recommend Rosewill Green, Capstone, Fortress and tachyion series PSUs they are rosewills quality lines that have one awards from many reputable reviewers such as anandtech and hardware secrets
so I would recommend http://www.newegg.com/Product/Product.aspx?Item=N82E16817182200
you can overclock both the CPU and a 680 to their limits with that PSU, also you said your budget is 1K, so does this mean you haven't built the computer yet, if you'd like I can get you a WHOLE lot better than just a 660 for your 1K budget.
here is a 1K budget gaming computer complete with i5 3570K, GTX 680, and 8GB of 1866 9-10-9 ram
now enter these promo codes
  • EMCXWVS226
  • EMCXWVS44
  • EMCXWVV37
  • EMCXWVS22
total after shipping and instant promo and combo discounts $1,006.93
also comes with a $10 newegg card in the mail so when it comes in migh as well grab a snazzy fan or heat sink for your CPU
You guys didn't get where I was going. I already have a current build and will be upgrading soon. With the upgrade I'm also changing my PSU but not really sure what amount of watts it would need with the components I wanted.
So to get the more accurate PSU I was requesting a calculator of some sort to input the options. You both did give me some new information though.
http://www.extreme.outervision.com/psucalculatorlite.jsp
if the link works :S
I've tried that just wondering about its validity. I input everything and tested the difference with 1 fan and the watts would jump by 20-30.
yeah its fine, cos with the fan option it doesnt give a make model rpm or other effecting stats  it just assigns an ammount that will cover most if not all fans available.
