Ps4 does it work with DAC?
I’m going to get a ps4 an i want to use my beyerdynamic custom one pro for it but no 3.5 mm jack, so i want to get a DAC but i don’t know if this DAC ( link down below) will work on a ps4 at all i need some help. if you any onther great DAC’s let me know.
link for the DAC Audio Video from LINDY UK
It should, if you have an optical cable for your PS4. (I don't know if the PS4 supports usb audio out) Anyway, for the price of a ps4 plus that amp, you could create a decent gaming PC with a decent sound card or amp. Regardless, I can assure you, you don't need a $400 amp/dac for a $200 headphone. Something like a fiio E07k might be adequate, if that doesn't fit the bill, I wouldn't go any higher than a HiFiman EF2-A.
Seconding this.
Already got a good pc with a asus xonar essence STX soundcard. oki so a E07k or a HiFiman EF2-A I’m gonna have a look at, thank you
