This Monitor: https://pcpartpicker.com/part/acer-monitor-umvh6aa003
I want to connect my ps3 to this monitor via HDMI until I noticed that there are no speakers on it to connect my headset to the audio jack in the back. So how can I use the monitor for video and something else for auido?
okay ps3 is really cool about what you can do with your audio visual options you can set the video to say HDMI out and plug in any composite/component cables that came with PS1/PS2/PS3 and set it to output the Audio out the Red and white cables and plug those into a speaker system, or use a adapter that changes the ends to 3.5mm for headphones or if thats what all your speakers only take, or if your rich the SPDIF out
Thanks! Really helped. I opted for a cheaper better monitor with built in speakers and 2 hdmi for pc and ps3. Another question does the msi 770 oc gaming edition 2gb output audio through its HDMI port?
