PS3 and Xbox controllers for pc use
Hey guys,
I have a lot of ps3 and xbox controllers laying around (I'm new to the pc master race, I built my computer like 7 months ago). What software or hardware would be required to use my old controllers with my new PC? Thanks in advance.
hardware: Bluetooth adapter for wireless dualshocks, xbox wireless adapter (amazon it, around $15) for wireless 360 controllers
software:
  • xpadder is good to have for anytime you need to bind a controller to keyboard/mouse inputs
  • x360ce is one tool to turn direct input controllers into xinput
  • motionjoy is like x360ce, works well with dualshock3 I haven't been able to make it work with anything else
For PS3 Controllers, you can download Motionjoy. its a Free App that you can use so that Your PS3 Controller can be used on your PC it's good for the PS2 or PS1 Emulator. You need to Make Sure your PC has Bluetooth, if Not you can find a Bluetooth adapter for $10-$20. or Just Connect Your PS3 Controller Via USB.
For Xbox 360 Controllers, You DEFINITELY need to buy a Xbox 360 Wireless Adapter is $20 Dollars online, the Adapter comes with instructions on how to set it up.
Now in terms of PC Gaming with a Controller. you  don't want to really game with a PS3 Controller. its possible to PC game with A PS3 Controller and there is nothing wrong with it but PC Games For Some Reason they are all Optimized to work with an Xbox 360 Controller. so You're better off using a Xbox 360 Controller to Game on PC.
I have to disagree there, you can use the PS3 controller just fine for any PC game out there. Simply emulate an Xbox 360 controller on it (the layout is pretty much the same after all) and just use it like a 360 controller. The MotionInJoy drivers can do this, and I had zero issues with it so far. I know many people prefer the shape of the 360 pad, but the PS3 controller simply has a superior D-Pad. I could never use the 360 pad for fighting games or 2D games.
Thanks so much guys didnt expect to get such great and detailed answers!
I am new to PC gaming also. Thanks for the info.
This site does a good job showing you how to set it up with Motionjoy:
http://www.hardcoreware.net/how-to-use-a-ps3-controller-in-windows-8/
