I’m looking to experiment with Proxmox server where I would run my “daily driver gaming pc” windows 10, freenas, plex server, zoneminder, pihole and couple other mainly ubuntu based vm’s. Backbone of the system would be a Ryzen processor, possibly something like 3800x or 4000 equivalent with 32-64gb of ram.
I would need to passthru a dedicated GPU for windows vm, and I would have another weaker one for proxmox itself and vnc to other vm’s when needed. nVidia or AMD for this? Should they be same brand or even same model? Any specific series of cards to avoid? Any recommendations? I have MSI Armor RX580 8G in my current windows rig and power wise its fine for now… I’m open for upgrading tho…
They should be different if possible, same brand is fine, but different GPU. This is because the best way to enable the VFIO stub driver is for all cards that have a PCIe ID, so if you want to pass through one card and leave the other for the host, then use different models so the VFIO is only enabled for one.
Nvidia gaming cards(GTX/RTX) are purposefully don’t work when they detect they are running(See code 43 issues). Quadros work fine but are much more expensive.
AMD cards, in general, have a reset bug that mean you need to reboot the host before you can restart the VM with the GPU passed through. There is work ongoing to fix this.
