Proxmox on One machine
Is there a way to use proxmox with a VM of windows running on one box without using another machine to login with a browser? If so would it make a good workstation solution providing the hardware is good. I have a Minisforum MS01 with i9 13 gen and 64gb ram. Wanna use it likt that and as a server for stuff around the house until i build my workstation.
You’ll need to access the webui to configure it but once it’s set up with GPU passthrough for the Windows VM it should work the way you want.
Yes. Just ensure that the network that your Proxmox install connects to is reachable from the network the Windows VM connects to (pretty simple if all you have is one network with DHCP, like a normal consumer router) and access it from the VM, whether it’s the web UI or SSH. That’s what I’ve been doing for years for my workstation, at least.
Ok excellent. Will i lose performance significantly operating this way? Will i be able to do the hone setup with NAS, pi hole etc on the same machine but also have thw ability to open my VM on this same machine? I am new to the passthrough concept but if i understand correctly it will allow me to use yhe server the way i want.
no, it is a fairly common configuration for home labs.
short answer: yes*
long answer: your ‘primary desktop machine’ will actually be a VM. you will be able to get to anything you want, but your ‘desktop computer’ vm will need to be running.
yes, ask questions as you go, there are some steps that can get confusing quickly.
Ok thanks alot
Food for thought, here’s how I keep my machine in the garage, so the only thing in the “computer” room is a monitor, peripherals, cables and an old laptop just in case:
I do not recommend trying to make a “do everything on one machine” setup on purpose, as that tends to be a fragile construction and these days there are probably better low power strategies (back then epyc was the best way to get PCIe lanes). However if the machine you already have or need can fit your desktop gaming needs, then it can be a good fit.
Well i spent 8 hours installing and reinstalling proxmox and windows today. 6 hours in ai realized browsers sometimes are an issue and realized my my MAC browser wasnt playing nice. Up and running with one VM through my MAC as a client and the MS01 as host with Proxmox on it. I notice its pretty snappy running thia way but getting my 3 monitors up with decent reaolution is going to be a chore i think. The MACbook screen is a little blurry and i do notice the mouse trailing a bit. I appreciate the input. I intend to watch a few more videos and learn how to optimize with what i have here before buying more hardware. Id like to get the worksation piece running smooth then add the other options as i get motivation. I was thinking about doing the PFsense on this machine as it has alot of peripherals but that may be more than my patience with bear!
Hi there again. So i have proxmox 8.1 up and running and attempted to do the sriov wendell and strongtz put together. It appears i need to use an older kernel among other things and im just learning linux.
Secondly i may just buy another video card but given space is limited is it a bad idea to perhaps mount the mso1 in a larger case so i can use my full height card?
Proxmox 7.4 is available and still supported, might be easier to reinstall with it.
Some of those minis-forum devices are fairly custom. I think it might be a lot of work to remount that board.
Ive been trying to install from the usb again. The drive is aknowledged and i get to the istall screen. I install 7.4 but before it gets to the gui it says it failed. Ive deduced it may have something to do with the DKMS.conf. i messed around with that but why would there be issues when i try to clean install 7.4? Appreciate the help
If you’re running Windows 11 in the VM, you’ll probably want to enable nested virtualization in ProxMox so you can use the virtualization based security features in Win11.
How to Enable Proxmox Nested Virtualization - Virtualization Howto
Do you really want to use sriov as base for a vfio workstation beginner project? Full GPU passthrough is already a edge case, but srvio is a hackjob especially with consumer cards and can easily break.
As a sidenote, I really appreciate what Wendell is doing, and it is great to see what is possible even with standard PC HW. But he is also far above my level of Linux knowledge. Here is my translation:
„There might be a bumps here and there.“ - takes at least a couple of hours to figure out.
„Encounter slight problems“ - Takes days of trial and error and research
„There is one problem“ - better take your university course now :slight_smile:
You know I agree I may be way above my paygrade and dont need it really. I just want to have access to hardware accelleration. Theres probably better ways for me to try first.
Ok if i make it that far ill try that. Is that related to the sriov or is that another solution entirely. Thanks
GPU passthrough is dedicating one GPU to an entire VM. It is supported by Proxmox without installing additional drivers / software and also persists through system updates. It still has some prerequisites (must be enabled in UEFI/BIOS; boot kernel arguments must be set, drivers blacklisted, compatible GPUs must be used):
https://pve.proxmox.com/wiki/PCI(e)_Passthrough
SRVIO would theoretically be the better solution. The host exposes vGPUs and these can be attached to the VMs. Its IMO less “low level”, it might even be a future solution to issues like GPU resets (mostly AMD, the GPU is stuck in a unuseable state and cannot be attached to another VM) - with srvio the GPU keeps beeing managed by the host. It might be possible to use other virtualisation features again for VMs with GPU resources - like memory balooning (making unused RAM availble to other VMs / host even if it is provisioned)
In praxis though, you need additional software, modified drivers and driver scripts (NVIDA) or very “hot-baked” experimental drivers and Kernel versions (Intel). This aren’t things which should be loaded onto a hypervisor, if you want a stable platform as base. And its not really beginer material.
Hi there. Thank you for the in depth response. I have decided to use the passthrough of one GPU to my main VM machine. Ill wait for the more experienced folks to sort that out.
As of now im trying to clean install proxmox and keep getting hung up . it gets to the screen where you commit to instal and ends in a failure. Ive played with the USB drive and tried various installs.
Is there a way to force install it? I messed with the .conf files aand some other stuff trying to get the SRIOV to work and im concerned i might have messed somethi8ng up although i can still boot into the installed version. Thanks
