So I thought I'd give proxmox a run. (Currently running Proxmox v4)
I've currently got it installed on a server. (E3-1230v2, 32GB DDR3 RAM, 120GB SSD, 500GB HDD, /29 IPv4)
Since my the data centre I use does not have proxmox on their supported list, they performed a best effort install.
I'm attempting to assign more than 1 IP to the machine, it has a /29 subnet allocated (107.X.XXX.122 - 107.X.XXX.126).
I'm fairly sure this is an easy process however I cannot remember the previous configuration I used, on my windows server in order to setup the IPs.
Any recommendations on what to do? I can't seem to find any online resources that will help.
I requested the OS to be installed on the HDD and the server also has a 120GB SSD, however it appears to only have 317GB disk space usable, with a 500GB HDD installed.
They've also mounted the SSD as /SSD (For reference)
Anyone have any thoughts on the drive allocation?
Or would it be best to get a KVM connect and manually install the server again?
Thanks!
