Compnent | Specs |
CPU: | Xeon E3 1246 3.5ghz |
Motherboard | Supermicro X10SLL-F |
Memory: | 16GB ECC Kingston KVR13E9K2/16I |
Storage: | WD blue 1TB, WD red 2TB |
Operating System: | ProxmoxVE 5.2 |
I’m jumping into the “not-windows” computer pool trying to learn to swim. I’m looking for advice on how to best use what i’ve got on hand. I’d like to set up a proxmox server so I get familiar with linux via different projects.
In proxmox I’d like to set up a camera server using Zoneminder. Nothing crazy 2-3 cameras but the ability to expand it in the future. I also intend to host winserver 2016 and others.
How can I best use the 2 drives that i have?
Another option i have is 3 2TB seagates (not sure which product) that are in a z1pool in my freenas. I hesitate to use these because i dont have a lot of confidence in their health. Nothing has happened to them yet but i made some poor choices in setting up. For one i installed my plex jail on that volume, from what i understand that means the drives have constantly been spinning for years now. The PSU had issues only one set of sata connectors worked, i dont know what else may have been wrong with it. They have also spent last week operating at 110F as i forgot to plug in my fan hub.
Thanks.
