Hey all, I’m following the Craft Computing guide recently posted (link removed, too new - search for video in posting title). I’m curious if my mostly-useless P106 card can be used as a Quadro so I can actually use it for something useful. Specifically I’m after 265 encoding, mostly just to use this card for a few VMs to get higher-fidelity remoting, possibly for some emulator gaming with friends. But mostly, I’m just curious if this will work.
I’ve gotten through the whole process, here’s some info:
lspci -k -s 04:00.0
04:00.0 3D controller: NVIDIA Corporation GP106 [P106-090] (rev a1)
Subsystem: ZOTAC International (MCO) Ltd. GP106 [P106-090]
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_vgpu_vfio, nvidia
mdevctl types
nvidia-46
Available instances: 23
Device API: vfio-pci
Description: num_heads=4, frl_config=60, framebuffer=1024M, max_resolution=5120x2880, max_instance=24
cat profile_override.toml
[profile.nvidia-46]
num_displays = 1
display_width = 1920
display_height = 1080
max_pixels = 2073600
cuda_enabled = 1
frl_enabled = 60
framebuffer = 984263338
pci_id = 0x1B3011A0
pci_device_id = 0x1B30
cat 102.conf
args: -uuid 00000000-0000-0000-0000-000000000102
bios: ovmf
boot: order=scsi0;ide2;net0
cores: 4
efidisk0: fast:vm-102-disk-1,size=1M
hostpci0: 0000:04:00.0,mdev=nvidia-46
ide2: foinix-proxmox-content:iso/pop-os_20.04_amd64_nvidia_17.iso,media=cdrom
memory: 5048
net0: virtio=C2:67:EF:D9:CA:33,bridge=vmbr0,firewall=1
numa: 0
ostype: l26
scsi0: fast:vm-102-disk-0,size=120G,ssd=1
scsihw: virtio-scsi-pci
smbios1: uuid=c7629ed6-554c-478a-b389-c089ba05d2b7
sockets: 1
vmgenid: e2a12577-cc1a-4729-97b0-889b1dba5a59
tried to start; I get this output.
qm start 102
mdev instance ‘00000000-0000-0000-0000-000000000102’ already existed, using it.
kvm: -device vfio-pci,sysfsdev=/sys/bus/pci/devices/0000:04:00.0/00000000-0000-0000-0000-000000000102,id=hostpci0,bus=pci.0,addr=0x10: warning: vfio 00000000-0000-0000-0000-000000000102: Could not enable error recovery for the device
kvm: -device vfio-pci,sysfsdev=/sys/bus/pci/devices/0000:04:00.0/00000000-0000-0000-0000-000000000102,id=hostpci0,bus=pci.0,addr=0x10: vfio 00000000-0000-0000-0000-000000000102: failed to read device config space: Bad address
start failed: QEMU exited with code 1
any thoughts on what i screwed up here? or is what i’m trying to do actually impossible, not just silly?
chur
