Proxmox 7.2 AMD s7150 MxGPU error `gim error:(init_register_init_state:3641) Failed to INIT PF for initial register 'init-state'`
Hello, I have tried to read everything I could find regarding this subject and have made it pretty far on the knowledge provided by others. I have done the following:
  • successfully compiled AMD GIM using the updated repository which was patched for kernel 5.0+
    *enabled GIM to load on startup
  • made sure amdgpu drivers are blacklisted
I am at a point now where the virtual GPUs seem to initialize, however I get this error and when I try to launch a VM after assigning a vGPU in proxmox the whole system crashes and reboots.
- - - - AMD PCI-e devices - - - -
02:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Tonga XT GL [FirePro S7150]
02:02.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Tonga XTV GL [FirePro S7150V]
02:02.1 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Tonga XTV GL [FirePro S7150V]
02:02.2 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Tonga XTV GL [FirePro S7150V]
02:02.3 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Tonga XTV GL [FirePro S7150V]
02:02.4 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Tonga XTV GL [FirePro S7150V]
02:02.5 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Tonga XTV GL [FirePro S7150V]
02:02.6 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Tonga XTV GL [FirePro S7150V]
02:02.7 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Tonga XTV GL [FirePro S7150V]
[    7.583546] gim error:(wait_cmd_complete:1683)  wait_cmd_complete -- time out after 3.000075060 sec
[    7.583579] gim error:(wait_cmd_complete:1692)   Cmd = 0x17, Status = 0x0
[    7.583600] gim error:(dump_gpu_status:1417) **** dump gpu status begin for struct adapter 2:00.00
[    7.583652] gim error:(dump_gpu_status:1457)  mmGRBM_STATUS = 0x3028
[    7.583676] gim error:(dump_gpu_status:1460)  mmGRBM_STATUS2 = 0x8
[    7.583716] gim error:(dump_gpu_status:1463)  mmSRBM_STATUS = 0x20000040
[    7.583734] gim error:(dump_gpu_status:1466)  mmSRBM_STATUS2 = 0x0
[    7.583751] gim error:(dump_gpu_status:1469)  mmSDMA0_STATUS_REG = 0x46dee557
[    7.583769] gim error:(dump_gpu_status:1472)  mmSDMA1_STATUS_REG = 0x46dee557
[    7.583793] gim error:(check_me_cntl:1388)   ME HALTED!
[    7.583807] gim error:(check_me_cntl:1391)   PFP HALTED!
[    7.583821] gim error:(check_me_cntl:1394)   CE HALTED!
[    7.583835] gim error:(dump_gpu_status:1588) **** dump gpu status end
[    7.583852] gim error:(init_register_init_state:3641) Failed to INIT PF for initial register 'init-state'
AMDVBFLASH version 4.69, Copyright (c) 2020 Advanced Micro Devices, Inc.
adapter seg  bn dn dID       asic           flash      romsize test    bios p/n
   0    0000 02 00 6929 Tonga           GD25Q41B         80000 p- - - - AMD PCI-e devices - - - -
   0    0000 02 00 6929 Tonga           GD25Q41B         80000 pass 113-C76720NOSRIOV
Does anyone have any experience with gim error:(init_register_init_state:3641) Failed to INIT PF for initial register 'init-state' and getting past this?
There have been so many tiny things that have held me up with this process and have been overcome that I feel this is also one of those instances of me having something just slightly misconfigured.
