Project Personal Datacentre
The long-term target for this project has moved.
The macOS VM may be replaced with either Project:ArcZ or ravynOS. We’ll end up losing iMessage capabilities (AirMessage), iTunes Purchase/Library Sync capabilities, and Time Machine backup.
All movies and music will have to be purchased as physical CDs/DVDs/Blurays or digitally via alternative storefronts.
Time Machine will be replaced with either Timeshift (Linux) or hypervisor-level utilities.
We’ve also started moving from PleX to Jellyfin, which means that Tautulli will be replaced as well.
Tautulli is getting replaced by either Tracearr or Jellystat.
Jellyfin also has AD/LDAP authentication support.
Radarr+Sonarr+Prowlarr will remain on the project.
For the next phase – DL580 Gen9
Disconnected the HP Smart Array P830i Controller and kicked the Creative Sound Blaster Audigy Rx.
Using a TASCAM US-16x08 for audio with the Windows VM.
Current Solution Draft:
  • use LSI 50031 9400-8i8e as primary HBA (upstream)
  • use HPE 727250-B21 (SAS expander) as downstream
    • connected via SFF-8087 to SFF-8643 cable
  • connect top 5 SAS bays via HP double-wide SAS to SFF-8087 cable
  • connect bottom 5 SAS bays via (2x) SFF-8087 cables
  • set LSI 50031 9400-8i8e as bootable storage controller in BIOS
Will test this once the SAS expander arrives in the mail.
Fixed a typo/left-over line from a previous edit, in the WIndows VM(s) descriptions for the next phase.
ManageEngine Endpoint Central has been kicked from the project. OPSI will handle application/OS deployment and patch management.
MariaDB will be hosted on a dedicated Linux VM with the next phase.
Cant wait to test this out:
