Project OldSchool
So, i got my hands on an old PC.  I mean really old.  As far as I can tell, the specs are as follows:
  • Pentium III @ 933 MHz (Yes, "M" as in megahertz)
  • 128MB PC-133 SDRAM
  • ATI Rage 128 AGP Graphics (Was really hoping for a Voodoo 3 here)
  • 20GB IDE HDD
  • CD-RW
  • I think the other optical drive is a CD-ROM
  • 1.44MB floppy
  • Iomega ZIP-100
  • 250W PSU
  • Old Beige A-Open Case
With the help of carbon 14 and radioactive dating, I have determined this PC to date back to approximately mid-late 2000, possibly early 2001.  The plan is to take all of that once top of the line hardware out of the case and install it in a cylindrical container that some can argue is the inspiration of the design for the new Mac Pro.
As for the pubescent beige case that happens to be the same standard ATX form factor as modern cases, I plan to build a modern rig in it.  Of course, building a modern PC in an old chassis isn't all that challenging, so I'm going to up the ante a bit.  I want to build a machine that can play modern games at medium-high settings and get playable frame rates.  Something a casual gamer would be happy with.  Here is the hardware I picked out:
  • http://www.newegg.com/Product/Product.aspx?Item=N82E16819113331
  • http://www.newegg.com/Product/Product.aspx?Item=N82E16813131937
  • http://www.newegg.com/Product/Product.aspx?Item=N82E16820233541
  • http://www.newegg.com/Product/Product.aspx?Item=N82E16817139049
  • http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
  • http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
  • http://www.newegg.com/Product/Product.aspx?Item=N82E16812186176
The build poses a few challenges for me.  First is cooling.  The case looks like it has a single 80mm fan mount in the front.  No fan mount in the back.  The old P3 had a max TDP of 27W and the GPU didn't even have a heat sink on it.  Safe to say the fan in the PSU Was enough to handle cooling duties.  I think I'll have to add another fan by cutting a hole in the back of the case.
Second is the floppy drive.  I want it to work.  Unfortunately, the last motherboards that had a floppy controller were either LGA775 or Socket AM2.  So far, I think my only option is to somehow mount a USB one internally.
I'm open to any feedback on this build and will definitely post a log once I get started.
