Project Arc-Angel
New Case. New update. :).
Kind of digging the vertical bay res, but I'm wondering how that impacts the flow.
The pump is at the bottom, I havent noticed an increase in temps from my previous benchmarks, Even with my OC. And when I put in the foodcoloring, it took about the same time to mix throughout the tubing.
So I don't think much, if any.
Phantom I just bought this case and was going to do a bay res just like you did. Does the fill hole at the top get blocked by the 5.25 cage. I'd like to just flip it on its side to fill it will this be possible? How do you fill and drain yours?
