Programs Recommended for coding a game
As you can tell from the title i am thinking of coding a simple 2d/3d game with python. I want it to be simple, sort of like the game Baldur's Gate. I sadly only know how to code using python although i might consider coding it with another programming language if there are more advantages.Thats why i need your help, i made a "list" of things that i "think" i need.
Things i Think i need:
  • A Game Engine
  • A Programming Language
  • A cool IDLE for that Programming Language
  • A software to create textures
  • A code compiler
  • A software to create sound filesĀ
Thanks in advance for all the replies and feel free to correct and add more program needed.
So with Game development usually you have a team for everything.
Creating everything yourself is a very long process and can be quite well, boring, at times.
As far as game development goes you can get Unity3D for free, its complete game engine with a quality API behind it which makes it really easy for new programmers to learn and really effective for professionals to use. It comes with its own version of MonoDevelop and thats really all you need for Unity.
When it comes to creating audio its really not just straight cut make audio done. You have to have a synthesizers/VSTs, and a DAW with the know how to create music essentially. A lot of people use FL Studios or Ableton live, but the learning curve on the two can be quite steep for someone who is not musically inclined and doesn't spend 20+ hours a week playing or writing music.
Creating textrues is most commonly done in Photoshop which I'm sure is easily guessed. Its just images, so yeah. There is Gimp and Paint.net. Otherwise if you're going for pixel art I use Aseprite, but I'm writing my own software since it seems to quite lack in some of the functions I would like to have.
TL;DR: Unity3D, Gimp/Photoshop, Ableton Live/FL Studios.
If i use the unity3d engine, how can i create 3d textures in photoshop. Its then any other game engine that you know?
Devon gave a great reply. I just wanted to also add that there is free access available to CryEngine, Unreal Engine, and Source Engine. While i am the farthest thing from a game developer, i have dabbled in modding from time to time (i mean, really, who wouldn't want to be a video game developer?!).
Creating textures in photoshop can be as simple as creating a 256x256 pixel imagine and using the paint bucket to dump in a color of your choice OR it can be as complex as a 2048x2048 pixel image that has a PSD that weighs in at 100s of mb. Things were awfully different when i started - we often started with a photo reference and layered hand painted details on top of that and then hand painted in lighting (before shaders existed to the extent they currently do). Modern workflows are very complex and require the artists to have a solid understand of the technology they are working with.
My advice would be to download the Source SDK on steam. The source engine is probably one of the simplest and user friendly engines available to tinker with (Unreal and Cry are quite complex). Maybe its because i started tinkering on the half life and modified quake engines, but i just feel the most comfortable when i play with Source. Maybe i just perceive it so or maybe it actually has good legacy support, that's a bit above my pay grade. Additionally, Valve has a LOAD of documentation available for those looking to make games for the source engine. So I really recommend you take a look at the Source engine and read through the Valve developer community documentation. It really gives you a great foundation and i think you can take - at least the concepts - you will learn there and apply them to other projects and technologies in the future.
https://developer.valvesoftware.com/wiki/Main_Page
Best of luck!
Thanks for all the replies i am now contemplating between the two engines to see which is best for what i am looking for. But I am still open for suggestions on any of the other aspects. :)
I downloaded the sdk and it seems like it's heavily design for modding purposing. I dont quite understand how to use it to create a game so could you please enlighten me?
python and java
Unity is a really good choice for starting, that's where I am currently at. The reason I say its good is because scripting is easy ish to learn and it implements well with visual studio or monodevelop and it also has the asset store, so if you aren't interested in modeling or just want to grab a quick script, that's what its there for.
But that's not to say that if you decide to go with udk or cryengine that those will be worse. Honestly just try all 3 and see which you are more comfortable with and then learn on that one.
I actually have a question related to making games- what is a good program to make 2d/2.5d games with?
Unity3D can do it as well. When creating a project just make sure that it is in 2D Mode. They recently added it.
For creating 3D Models there are a range of programs you can use from beginner to professional.
For casual sculpting you can use a free program by a very popular company called Pixologic. This program is Sculptris. I just want to make it clear that you should under no circumstance make this your only modeling program for games. As the poly/tri count goes insane in it since its only made for sculpting, not optimization.
If you're ready to start as a somewhat professional modeler I use a program called ZBrush. By the same people as sculptris ZBrush is literally the end all god program for creative model design. The work flow is a bit unconventional by average program standards, but the second you have any idea what you're doing you essentially become 3 times more efficient than people trying to use the other programs listed below. ZBrush as well, should not be your only program for modeling. Its good, it does Diffuse mapping, Bump/Normal mapping, UV Mapping, Specular mapping as well, but it doesn't do animation the best and that is why I don't use it for everything.
When going for an effective program there are a lot of programs you can use. 3DS Max and Autodesk Maya are common among many professionals as they, before zbrush, were a common standard and the best in their time. They're still amazing programs, but nothing near the efficiency of zbrush. They're open to students but carry a hefty price of around a few thousand dollars.
Blender is my personal favorite program when paired with zbrush. With the two I'm able to create just about anything I can imagine. Blender is good for casual static meshes, so things like crates, some simple guns, and low detail buildings.
All of the programs listed above are good for animation except for zbrush and sculptris. However that does not change the fact that you can animate in zbrush, I just do not find it as effective as the other programs.
If you're new you'd be much better off learning to code for a mod. Source is a good start indeed.
There's no point biting off more than you can chew, making a big project and abandoning it soon after. Start small.
I am thinking of using the cryengine for my game. Thanks for all the comments and suggestion guys.
A WebBrowser...
Learn JavaScript/JQuery/HTML5 an you will be good to make a game!
