Considering buying a new monitor, since I'm a programmer I have long wondered if a monitor that can turn sideways(so its long not wide) would be useful for a programmer. Since the code statements are short a wide monitor is usually not of much use to me, seems like it would be really handy to be able to read more lines of code without scrolling down. Anyone have any experience with it?
I try to only write to 80 columns - and since most of my work is with lists, anyway, I love using portrait. I use portrait monitors almost daily, but I often switch them around quite a bit ever since I built my monitor stand.
80 cols master race!
Some of the projects I contribute to have a strict 80-cols readability linting. Sideways monitors rock a bunch. You can get some monitor arms and it works well.
Whenever I want to code something in portrait mode I just flip my whole LCD and put some books under it so that it wouldn't fall. While this is not a very elegant solution, it is one so and if you find a good monitor without pivot, don't let it be a deal-breaker. Also portrait mode rocks for programming.
portrait mode + coding = ftw
A big criticism about programming is that we are effectively looking through a small letterbox onto a complex [messy] masterpiece!
With a vertically oriented monitor, you're at least increasing peripheral awareness of the file your looking at. One downside is that your scroll-wheel finger will get less exercise.
