Programming 101
Hey Guys, I had a question for all of you about what code language would be the best to learn for a beginner programmer. I'd eventually like to be able to assist in the developing of games, and I just dont really know what language to start with.
Thanks,
Race
Start with Python.  It's the starter language for just about everyone, and it will teach you everything you need to know.
Well, if you started awhile back, DOS really is the starter language. I'm not saying you're wrong but most people just dive into C++ or Java, tho often do start with HTML/JavaScript since they're simple.
I would recommend learning DOS personally, because most languages are formed on the language, C++ is a good second language or even first if you're feeling daring. C++ is pretty much a must, but not really at the same time. Programmers who know C++ are generally the ones who understand at the lower levels of things and can make the more complex programs. Tho not all programmers are like that.
+1 for C++ :)
But isn't C++ just a library for C?
No, no, no, no, no, no, no, no, no, no, no!
C++ is an extension to C++ that has added so much functionality, but still has a lot of the functions from C available. Over the years, however, it has become so feature-rich and much more modern than C, that the only reason to use C is if you are trying to make a simple OS and are too lazy to use ASM. C++ is its own language, but can be thought of as C V2.0.
C++ teaches you the C Context, which is a form of writing code. C Context is used throughout all C based languages. AKA Java, C++,C#,Objective C, and a few other odds and ends. C++ is another form of C but is generally regarded as a standard language itself because of the size. If you would like to learn more: https://en.wikipedia.org/wiki/C%2B%2B
As I understand it, C++ is more Object Oriented, than C.
Much more. That is not to say you can't write C object oriented, but C++ is much more up for the job.
C++ is the most annoying language I've ever dealt with.  I can't believe the amount of times I've seen it recommended as a starter language.  People need to learn programming concepts before actually programming.  For anyone starting out, C++ wil merely frustrate them into giving up.  Python teaches those with minimal code, so it's easier to grasp the concepts.  Something like VB would be even better, or use a flowchart program like Raptor.  C++ is probably one of the worst languages to learn how to program on.
