whazaaa, can anyone suggest a program that I can use to monitor my temps in windows? cause I wanna run prime95 and check my cpu temps.
Hwmonitor and Core Temp are the 2 i use
I use core temp for my CPU and MSI afterburner for my GPU. Core temp does not seem to work quite well with APUs
thanks guys, I'm using hwmonitor now, works like a charm
