Fyi the product description has instructions about contacting
this is the level1t community site; don’t know that people in the community will always respond immediately to questions.
I’m a bit confused over the USB-C / Thunderbolt4 (currently have two) and DisplayPort 1.4 specs.
displayport is not usbc. usbc has less bandwidth for the display than displayport 1.4.
your title seems to reference displayport 1.4 but neither the mac studio nor macbook pro have displayport. how are you getting displayport?
the usbc kvm might be a better choice for you, and it’ll charge your mac laptop, unless you have one of the displays that uses almost all the dp1.4 bandwidth like the samsung g9/g9 neo or a monitor with a res and refresh near 4k/120hz which is near the limits of dp1.4
apple, in infinite wisdom, does not yet properly support display stream compression except in a few narrow scenarios (nothing to do with the kvm)
the kvm is also not a thunderbolt dock or thunderbolt switch so in some scenarios apple devices will complain about usb depth being exceeded when you combine a dock that has lots of usb ports with a mac because the dock also has an internal usb hub, which using on top of the kvm with its internal usb hub, can cause you to have to directly connect the usb part of the kvm directly to the mac.
the usbc doesn’t generally have that issue though since it connects via usbc.
into the same Mac Studio display
If this is a thunderbolt display and you want thunderbolt or thunderbolt daisy chaining to work, don’t think there is anything on planet earth that will work for you. even the usbc kvm is regular old displayport out.. which full-size displayport doesn’t carry usb signals so no usb function would work on something connected to any kvm via displayport.
you might, maybe, be able to add the level1techs dp+usb signal combiner to the mix to go out of the kvm, into the adapter, and then into a usbc-compatible display. I have tested this on the usbc lg display that has usbc in and it works at 4k/90hz no problem, with usb3 speeds, but afaik no one has tested any actual thunderbolt displays. apple usually doesn’t care to test any non-proscribed scenario either so I dont know I’d recommend it.
