Hi,
So my friend bought a Gigabyte GTX 680 SOC on Ebay and he is about to buy the rest of the PC in a couple of days (Pretty much only for CS:GO). We are looking at the Prodigy M (m-ATX) case. The GTX 680 SOC has its fans on the top of the card instead of the front as well as being a rather tall card. Do you guys think that airflow might be a problem in the Prodigy M? Looking at the size of the case it shouldn't be a problem as long as I do not use the HDD mount. (He is only using an SSD).
Cheers, Stefano.
