RossQ
December 2, 2020, 3:22pm
1
Hi guys,
Before I begin, I have the latest version of Manjaro Linux on my system at the time of this post. With the latest non-experimental kernel installed.
I have a Bluetooth adapter for my system and it works in Manjaro, however, with my true wireless earbuds, I am unable to get them to work as a headset, as there is no recording option in sound for the mic and only seems to work as headphones.
I have looked around google and some articles suggest to change the audio profile, one program that can do this is Blueman. But upon trying to switch the audio profile it keeps saying failed ( I can’t remember the exact wording)
What are your suggestions?
You are going to need to give actual specifics if you us want help. Error messages, resource you used, and etc.
For example, what version of bluetooth is your adaptor?
Is it itegrated into your motherboard or is a dongle that you bought?
What version of bluetooth is headset?
Have you used these devices together with MS windows? did it work there? Was extra software required to use this setup on Windows?
RossQ
December 3, 2020, 2:25pm
3
Hi thanks for you for your reply
The adapter and wireless earbuds work perfectly fine in windows, so I know it is not a hardware issue.
I am using the Enacfire E60 Bluetooth version 5
I am using a Bluetooth USB adapter, unfortunately, I do not know all the details about the adapter as there is little information about it.
When I open “audio volume settings” and go to “Audio” then the “Advanced” tab. The earbuds are listed there, But only the AD2P Sink profile is available, which would explain I can not use them in Headset mode.
If I use Blueman it gives me the extra profile options like A2DP Source and HSP/HFP but I get the following error message.
“Failed to change profile to a2dp_source”
or
“Failed to change profile to headset_head_unit”
Ok. Now we have a baseline to work with. It is highly likely that the BT Module does not have proper support in the Linux kernel if it is a cheap knock off brand.
So, if you run a lsusb --verbose
to get a full dump of all attached usb devices. May need to sudo or run this as root for an accurate output.
Then run a lsmod
to see which modules are loaded. Again, may have to run this as root or use sudo.
Lastly, run a group
to see what groups you belong to. If I am not mistaken, you need to be part of the lp
group. You may also need to add the pulse
service account to the lp group as well. And since you are running Manjaro, also make sure to install the pulseaudio-bluetooth
package with packman.
Use the Arch wiki as a reference for troubleshooting. Provide any specifics that you run into here and we can help diagnose what is going wrong.
https://wiki.archlinux.org/index.php/Bluetooth
RossQ
December 10, 2020, 11:12pm
5
This is the output of lsusb --verbose
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 5
can't get device qualifier: Resource temporarily unavailable
can't get debug descriptor: Resource temporarily unavailable
Device Status: 0x0001
Self Powered
Bus 001 Device 005: ID 0a5c:4502 Broadcom Corp. Keyboard (Boot Interface Subclass)
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x0a5c Broadcom Corp.
idProduct 0x4502 Keyboard (Boot Interface Subclass)
bcdDevice 1.00
iManufacturer 0
iProduct 0
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0022
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 2mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 1 Boot Interface Subclass
bInterfaceProtocol 1 Keyboard
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.11
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 56
Report Descriptors:
** UNAVAILABLE **
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 10
Self Powered
Bus 001 Device 003: ID 0a5c:4500 Broadcom Corp. BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth)
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 0 Full speed (or root) hub
bMaxPacketSize0 8
idProduct 0x4500 BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth)
bcdDevice 1.00
iManufacturer 1 Broadcom
iProduct 2 BCM2070B0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 94mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 255
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 3
wHubCharacteristic 0x0004
Ganged power switching
Compound device
Ganged overcurrent protection
bPwrOn2PwrGood 50 * 2 milli seconds
bHubContrCurrent 100 milli Ampere
DeviceRemovable 0x0e
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.0103 power enable connect
Port 2: 0000.0103 power enable connect
Port 3: 0000.0103 power enable connect
Self Powered
Bus 001 Device 002: ID 12ba:00ff Licensed by Sony Computer Entertainment America Rocksmith Guitar Adapter
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 16
idVendor 0x12ba Licensed by Sony Computer Entertainment America
idProduct 0x00ff Rocksmith Guitar Adapter
bcdDevice 1.00
iManufacturer 1 Hercules
iProduct 2 Rocksmith USB Guitar Adapter
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0098
bNumInterfaces 3
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
iInterface 0
AudioControl Interface Descriptor:
bLength 9
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdADC 1.00
wTotalLength 0x0027
bInCollection 1
baInterfaceNr(0) 1
bLength 12
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 2
wTerminalType 0x0201 Microphone
bAssocTerminal 0
bNrChannels 1
wChannelConfig 0x0001
Left Front (L)
iChannelNames 0
iTerminal 0
bLength 9
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 7
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bSourceID 10
iTerminal 0
bLength 9
bDescriptorType 36
bDescriptorSubtype 6 (FEATURE_UNIT)
bUnitID 10
bSourceID 2
bControlSize 1
bmaControls(0) 0x03
Mute Control
Volume Control
bmaControls(1) 0x00
iFeature 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Streaming
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
AudioStreaming Interface Descriptor:
bLength 7
bDescriptorType 36
bDescriptorSubtype 1 (AS_GENERAL)
bTerminalLink 7
bDelay 1 frames
wFormatTag 0x0001 PCM
bLength 29
bDescriptorType 36
bDescriptorSubtype 2 (FORMAT_TYPE)
bFormatType 1 (FORMAT_TYPE_I)
bNrChannels 1
bSubframeSize 2
bBitResolution 16
bSamFreqType 7 Discrete
tSamFreq[ 0] 8000
tSamFreq[ 1] 11025
tSamFreq[ 2] 16000
tSamFreq[ 3] 22050
tSamFreq[ 4] 32000
tSamFreq[ 5] 44100
tSamFreq[ 6] 48000
bLength 9
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 13
Transfer Type Isochronous
Synch Type Synchronous
Usage Type Data
wMaxPacketSize 0x0064 1x 100 bytes
bInterval 1
bRefresh 0
bSynchAddress 0
AudioStreaming Endpoint Descriptor:
bLength 7
bDescriptorType 37
bDescriptorSubtype 1 (EP_GENERAL)
bmAttributes 0x01
Sampling Frequency
bLockDelayUnits 0 Undefined
wLockDelay 0x0000
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.11
bNumDescriptors 1
wDescriptorLength 26
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bEndpointAddress 0x87 EP 7 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 1
Device Status: 0x0000
(Bus Powered)
Bus 001 Device 004: ID 152a:85dd Thesycon Systemsoftware & Consulting GmbH SMSL M6
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 64
idVendor 0x152a Thesycon Systemsoftware & Consulting GmbH
idProduct 0x85dd
bcdDevice 6.f2
iManufacturer 1 SMSL
iProduct 3 SMSL M6
iSerial 0
bNumConfigurations 2
bLength 9
bDescriptorType 2
wTotalLength 0x011c
bNumInterfaces 3
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 0mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 1 Audio
bFunctionSubClass 0
bFunctionProtocol 32
iFunction 0
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bInterfaceProtocol 32
iInterface 3 SMSL M6
bLength 9
bDescriptorType 36
bcdADC 2.00
bCategory 8
wTotalLength 0x0048
bmControls 0x00
bLength 8
bDescriptorType 36
bDescriptorSubtype 10 (CLOCK_SOURCE)
bClockID 41
bmAttributes 3 Internal programmable clock
bmControls 0x07
Clock Frequency Control (read/write)
Clock Validity Control (read-only)
bAssocTerminal 0
iClockSource 9 SMSL Internal Clock
bLength 8
bDescriptorType 36
bDescriptorSubtype 11 (CLOCK_SELECTOR)
bClockID 40
bNrInPins 1
baCSourceID(0) 41
bmControls 0x03
Clock Selector Control (read/write)
iClockSelector 8 SMSL Clock Selector
bLength 17
bDescriptorType 36
bTerminalID 2
bAssocTerminal 0
bCSourceID 40
bNrChannels 2
bmChannelConfig 0x00000000
iChannelNames 11 Analogue 1
bmControls 0x0000
iTerminal 6 SMSL M6
bLength 18
bDescriptorType 36
bUnitID 10
bSourceID 2
bmaControls(0) 0x0000000f
Mute Control (read/write)
Volume Control (read/write)
bmaControls(1) 0x0000000f
bmaControls(2) 0x0000000f
iFeature 0
bLength 12
bDescriptorType 36
bTerminalID 20
wTerminalType 0x0301 Speaker
bAssocTerminal 0
bSourceID 10
bCSourceID 40
bmControls 0x0000
iTerminal 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
iInterface 4 SMSL M6
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
bmFormats 0x00000001
PCM
bNrChannels 2
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 32
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 5
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x0308 1x 776 bytes
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
bLockDelayUnits 2 Decoded PCM samples
wLockDelay 0x0008
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 32
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0008
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 2
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
bmFormats 0x80000000
bNrChannels 2
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 32
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0008
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 254 Application Specific Interface
bInterfaceSubClass 1 Device Firmware Update
iInterface 10 SMSL DFU
Device Firmware Upgrade Interface Descriptor:
bLength 9
bDescriptorType 33
bmAttributes 7
Will Not Detach
Manifestation Tolerant
Upload Supported
Download Supported
wDetachTimeout 250 milliseconds
wTransferSize 64 bytes
bcdDFUVersion 1.10
bLength 9
bDescriptorType 2
wTotalLength 0x011c
bNumInterfaces 3
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 0mA
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionSubClass 0
iFunction 0
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bLength 9
bDescriptorType 36
bcdADC 2.00
bCategory 8
wTotalLength 0x0048
bmControls 0x00
bLength 8
bDescriptorType 36
bClockID 41
bmControls 0x07
bAssocTerminal 0
bLength 8
bDescriptorType 36
bClockID 40
bNrInPins 1
baCSourceID(0) 41
bmControls 0x03
bLength 17
bDescriptorType 36
bTerminalID 2
bAssocTerminal 0
bCSourceID 40
bNrChannels 2
bmControls 0x0000
iTerminal 6 SMSL M6
bLength 18
bDescriptorType 36
bUnitID 10
bSourceID 2
iFeature 0
bLength 12
bDescriptorType 36
bTerminalID 20
bAssocTerminal 0
bSourceID 10
bCSourceID 40
bmControls 0x0000
iTerminal 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 32
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0008
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 32
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0008
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 2
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
bNrChannels 2
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 32
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0008
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
bLength 9
bDescriptorType 33
bmAttributes 7
Will Not Detach
Upload Supported
Download Supported
bcdDFUVersion 1.10
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 2
bMaxPacketSize0 64
Self Powered
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 5.09
iManufacturer 3 Linux 5.9.11-3-MANJARO xhci-hcd
iProduct 2 xHCI Host Controller
iSerial 1 0000:02:00.0
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 11
bDescriptorType 41
nNbrPorts 14
wHubCharacteristic 0x000a
No power switching (usb 1.0)
Per-port overcurrent protection
TT think time 8 FS bits
bPwrOn2PwrGood 10 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
DeviceRemovable 0x04 0x06
PortPwrCtrlMask 0xff 0xff
Hub Port Status:
Port 1: 0000.0100 power
Port 2: 0000.0100 power
Port 3: 0000.0100 power
Port 4: 0000.0100 power
Port 5: 0000.0103 power enable connect
Port 6: 0000.0103 power enable connect
Port 7: 0000.0100 power
Port 8: 0000.0100 power
Port 9: 0000.0100 power
Port 10: 0000.0100 power
Port 11: 0000.0503 highspeed power enable connect
Port 12: 0000.0100 power
Port 13: 0000.0100 power
Port 14: 0000.0100 power
Self Powered
Output of lsmod
Module Size Used by
snd_seq_dummy 16384 0
snd_hrtimer 16384 1
snd_seq 86016 7 snd_seq_dummy
rfcomm 90112 12
cmac 16384 2
algif_hash 16384 1
algif_skcipher 16384 1
af_alg 32768 6 algif_hash,algif_skcipher
bnep 28672 2
btusb 69632 0
btrtl 24576 1 btusb
btbcm 20480 1 btusb
btintel 32768 1 btusb
bluetooth 741376 43 btrtl,btintel,btbcm,bnep,btusb,rfcomm
ecdh_generic 16384 1 bluetooth
ecc 36864 1 ecdh_generic
snd_usb_audio 319488 3
snd_usbmidi_lib 40960 1 snd_usb_audio
snd_rawmidi 45056 1 snd_usbmidi_lib
snd_seq_device 16384 2 snd_seq,snd_rawmidi
mc 61440 1 snd_usb_audio
mousedev 24576 0
joydev 28672 0
input_leds 16384 0
hid_generic 16384 0
usbhid 65536 0
hid 147456 2 usbhid,hid_generic
squashfs 73728 0
loop 36864 0
nls_iso8859_1 16384 1
nls_cp437 20480 1
edac_mce_amd 32768 0
vfat 24576 1
fat 86016 1 vfat
fuse 139264 9
kvm_amd 114688 0
eeepc_wmi 16384 0
asus_wmi 45056 1 eeepc_wmi
battery 20480 1 asus_wmi
sparse_keymap 16384 1 asus_wmi
wmi_bmof 16384 0
rfkill 28672 8 asus_wmi,bluetooth
kvm 856064 1 kvm_amd
snd_hda_codec_hdmi 73728 1
snd_hda_intel 57344 2
snd_intel_dspcfg 24576 1 snd_hda_intel
snd_hda_codec 167936 2 snd_hda_codec_hdmi,snd_hda_intel
irqbypass 16384 1 kvm
uinput 20480 1
crct10dif_pclmul 16384 1
crc32_pclmul 16384 0
nvidia_drm 61440 4
mxm_wmi 16384 0
ghash_clmulni_intel 16384 0
nvidia_modeset 1220608 12 nvidia_drm
snd_hda_core 106496 3 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_cod
ec
snd_hwdep 16384 2 snd_usb_audio,snd_hda_codec
drm_kms_helper 266240 1 nvidia_drm
aesni_intel 372736 3
snd_pcm 147456 5 snd_hda_codec_hdmi,snd_hda_intel,snd_usb_aud
io,snd_hda_codec,snd_hda_core
ccp 118784 1 kvm_amd
igb 253952 0
crypto_simd 16384 1 aesni_intel
snd_timer 45056 3 snd_seq,snd_hrtimer,snd_pcm
cec 73728 1 drm_kms_helper
cryptd 24576 3 crypto_simd,ghash_clmulni_intel
glue_helper 16384 1 aesni_intel
snd 114688 23 snd_seq,snd_seq_device,snd_hda_codec_hdmi,s
nd_hwdep,snd_hda_intel,snd_usb_audio,snd_usbmidi_lib,snd_hda_codec,snd_timer
,snd_pcm,snd_rawmidi
sp5100_tco 20480 0
rapl 16384 0
rc_core 61440 1 cec
pcspkr 16384 0
k10temp 16384 0
i2c_piix4 28672 0
rng_core 16384 1 ccp
soundcore 16384 1 snd
i2c_algo_bit 16384 1 igb
dca 16384 1 igb
drm 585728 7 drm_kms_helper,nvidia_drm
agpgart 53248 1 drm
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
wmi 36864 3 asus_wmi,wmi_bmof,mxm_wmi
fb_sys_fops 16384 1 drm_kms_helper
gpio_amdpt 20480 0
evdev 28672 28
pinctrl_amd 32768 0
mac_hid 16384 0
acpi_cpufreq 28672 0
nvidia 28286976 698 nvidia_modeset
msr 16384 0
sg 40960 0
crypto_user 16384 0
ip_tables 32768 0
x_tables 53248 1 ip_tables
ext4 815104 1
crc32c_generic 16384 0
crc16 16384 2 bluetooth,ext4
mbcache 16384 1 ext4
jbd2 139264 1 ext4
crc32c_intel 24576 2
xhci_pci 20480 0
xhci_hcd 286720 1 xhci_pci
for groups I get sys network power lp wheel and my username
RossQ:
blue
Looks all good and well. I would suggest running a group pulse
to see if the pulse user is part of the lp
group. if it is not, then add it. Also verify that you have the pulseaudio-bluetooth
package installed.
