Problems with my Monitors
So I just finished my lightweight build today and when I was setting up my monitors and I noticed that only one of them was showing any output. The monitor that was showing the output was connected by DVI to the graphics card while the other was connected to the mobo.
For those who are wondering I am rocking two Dell 1905FPs and using an A8-6600k with a Radeon HD 6570
I'm not sure all these questions will apply for your AMD A8 APU but...
Is the monitor power cable/supply connected? Appropriate video cable connected? Monitor turned on? Check for any onboard/integrated graphics options in the BIOS. Do you have an up-to-date driver for the integrated GPU? Is the integrated GPU enabled (device manager)? Is the OS detecting both monitors?
Try removing the discrete GPU, connect a monitor to the integrated GPU alone and test.
Good luck!
