So here is my problem: I can get the installation for ubuntu to finish successfully, however after restarting the Computer grub doesnt show up only a black screen (the same happens if I start Ubuntu from live usb without safe grafics or starting manjaro from live usb) So this could be a gpu driver problem aswell.
I can always get into Bios though.
Secure Boot is disabled
Fast Boot is disabled
Ive tried both csm and no csm (I think)
Bios version is 3603 (latest non-beta)
build:
Ausu x570 TUF Gaming pro wifi
Ryzen 5 3600
MSI RX590 Armor
Crucial mx500 m.2 sata ssd
16 GB Corsair Vengeance LPX
be quiet 700w PSU
plenty of cooling
You can keep Secure boot on for Ubuntu. Have done a CMOS/BIOS reset? Is there a TPM chip present? If so, have you cleared it from the BIOS? You probably need to have a SWAP partition too. Can you use a different USB drive?
ok so here is the current situation: once im in grub (which I could probably have gotten to the entire time by holding esc on boot) if I choose to boot into recovery mode and then just resume normal startup I can boot normally however if I choose the standard option I get the Black screen
The RX590 should have mature open-source driver support by now. Either something with the motherboard, or the GPU is faulty. Can you check if the 2200G with integrated graphics and with the 590 unplugged works? Remember to plug in the display cable directly to the motherboard HDMI/DP. If you have a spare graphics card, you can try that first.
yes Before when I tried it I completely removed the card from the case and plugged into the motherboard hdmi.
unfortunately I dont have a spare gpu rn
But the system was behaving basically the same with the vega graphics
Ubuntu uses Gnome and Gnome uses GDM. Please go into /etc/default/gruband remove quiet from GRUB_CMDLINE_LINUX_DEFAULT and report if the issue is resolved. If not please report what you are seeing on the screen, since it should now be verbose.
