Problem with Starship/Matisse HD Audio Controller
Hello, everyone. I’m running a fresh install of Debian with i3-wm and I’m facing some problems with my headphone. My pulseaudio it’s running and I’m receiving output to my TU106 High Definition Audio Controller (as I could saw in pavucontrol). However, my Starship/Matisse HD Audio Controller isn’t receiving output at all.
Some kind of information that maybe should be useful for those who’ll answer:
lspci | grep -A 10 Audio
29:00.1 Audio device: NVIDIA Corporation TU106 High Definition Audio Controller (rev a1)
29:00.2 USB controller: NVIDIA Corporation TU106 USB 3.1 Host Controller (rev a1)
29:00.3 Serial bus controller: NVIDIA Corporation TU106 USB Type-C UCSI Controller (rev a1)
2a:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
2b:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
2b:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
2b:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
2b:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controlle
CPU: AMD Ryzen 7 5800X (16) 3800GHz
GPU: NVIDIA GeForce RTX 2060 Super
OS: Debian GNU/Linux 12 (bookworm) x86_64
Kernel: 6.1.0-28-amd64
I don’t get it. Why does your 5800X have on-board audio? What’s the motherboard, and which audio chipset does the motherboard have?
K3n.
It just identifies like that. I have a 5900X and it’s showing the same.
I had a 2700X in the same board before and it was showing a different name, it changed when I swapped in the 5900X.
I’m not entirely sure why that is but my assumption is that it’s part of the chipset (more specifically the northbridge), or at least the audio controller is connected through it.
That being said…
This needs some clarification. Are you just unable to hear anything on your speakers, or are the volume meters in pavucontrol also not peaking when audio is routed to it?
