Problem with Radeon 6850
Ok so I'm having issues with my new hd 6850 I installed it yesterday with no issues it worked fine. This morning however i got up decided to get on my pc and i got no monitor signal so i checked my dvi cable all my power connections reseated the card and memory changed out my power supply to no avail. So I tried the card in another pc and it works fine no issues at all.
Any suggestions would be appreciated.
System Specs
AMD Athlon II X2 250
2x2gb mushkin blackline ddr2 800
ASUS M2N32SLI Deluxe
Seagate Barracuda 1tb
western digital 80gb
western digital green 500gb
2 sony dvd/rw ide drives
sound blaster audigy se
killer2100 nic (it was a gift)
power supplies ive tried 580w mushkin, 600watt ultra xfinity titanium
What about your previous graphics card? does it still work? Could be the PCI-EX slot borked on you
Unfortunately no my 8800gts is dead and gone but im posting from the pc with a 4650.
take the 4650 out and see if it works in ur computer
the 4650 is currently in my computer
could it be PSU trouble? or driver problems?
hmm well i just tried my dads 750 watt and it still doesnt work
if there is nothing wrong wiht youre computer when running that card and u havnt changed anythign in youre system lately then you're card probably had a mlafunction of some sort if u can try it in nother pc and if still no avail then you're card went pbbttth but if it works in another system check you're psu then work and go from there
Well he said he already checked his psu.. Hmmm. Some weird bios settings? Maybe using onboard graphics instead?
^That is a really good possibility
ok so I swapped the cards many times and just noticed that if i hit the power button several times it will power on with the 6850 but if i just hit the power button once it wont output to my lcd and the gpu fan runs 100%
