Tazuna
November 26, 2013, 5:19am
1
Hey all,
I am trying to get OBS to record TESV:Skyrim for me but I am encountering problems. (Also cannot get it work with Bioshock: Infinite)
The frames are freezing/skipping. (EDIT: Noticing this happening when lighting effects come into play)
This is quite annoying.
Video: https://youtu.be/qsxnBPbQ2nE
Heavily modded, Might be my ENB.
CPU: FX 6300 Stock
GPU: HD 7950
Any suggestions/ ideas as to what is going on?
What CPU do you have? I often get that problem with skyrim a lot
i'd say it's both the cpu and the hdd.. if your playing on a ssd with the os then there would not be an issue
Tazuna
November 26, 2013, 8:45pm
4
I have a FX 6300 at stock clock. I don't think it would be the CPU, but I know nothing on the matter.
Tazuna
November 26, 2013, 8:49pm
5
Should I move OBS to my SSD? Or Skyrim to the SSD?
it's not the drives, but likely your cpu.
modded skyrim is pretty cpu-intensve, and the 6300 is not an 8350. don't try and use it like one. I would downscale to 480p, and lower the bitrate to 1500 or so. if you still have probs, bitrate to 1000. also make sure that the recording FPS is set to 30fps, even an 8350 can struggle with 60fps in some games.
Tazuna
November 26, 2013, 10:08pm
7
Hm. I figured it was mostly GPU intensive, But I will give it a try. Thanks.
EDIT: My CPU does not go past 30% wile running Skyrim and OBS, Im slightly confused as to what you mean by "CPU-Intensive"
Are you recording to the same drive that your game is on and if it's a Mechanical whats the size of the cache? What programs are be accessed on what drives at what times. Whats your buffer size for encoding?
Tazuna
November 27, 2013, 4:59am
9
Game and file are on same HDD, Don't know about the Cache(Its old so I'm assuming the Cache is quite small)
The only other program being accessed on that drive would be steam. Buffer size was 3000, now 1000. (Same as bitrate)
Tazuna
November 27, 2013, 5:00am
10
I have noticed that fire/lighting effects cause the skips/freezes.
Try turning down the "Quality balance" down to 2 in "Encoding"
he's probably using CBR. the QB is not used when using CBR
Tazuna
December 1, 2013, 1:38am
13
Anyone? Do I need to upgraid my CPU so it can handle this? I cant get it to work with Bioshock:Infinite ether.
