Problem with new GTX 660
   Yesterday I got my GTX 660 and it was running like a dream, playing all my games at max settings, couldn't be happier. However, this morning I noticed some crazy framerate drops whilst playing CS:GO, and I then checked it wasn't just a source thing, but I got a similar result in other games like SSF4.
   Now, ever since I restarted my computer, it doesn't recognise a GPU is plugged in and has reverted back to my integrated Intel HD. Could there be an issue with the GPU or am I missing something obvious?
Thanks
EDIT: My specs: Gigabyte z77-3dh MoBo, 3750k i5 processor, 8gb 1600 Kingston HyperX Ram, Seagate 500GB hard drive
Driver version, what are you using.
Ah no don't worry man, it turns out it was my crappy case being the problem, the screw hole for the card wasn't aligned and was forcing the card in at a funny angle and I didn't even realise, everything is fine now and running better than before, just need to consider a new case xD Thanks
