But here's my problem: I had a radeon 4870 graphics card, everyone was fine, but I decided to sell it to get a 7850, but while I'm waiting for the 7850 I decided to use my integrated graphics.
So first off I uninstalled everything related to ATi from add/remove from control panel, second thing I did was use driver sweeper to delete all the ATi related drivers, so I rebooted my pc with only integrated graphics.
I went to AMD's site to download the newest drivers, installed them, and rebooted, but on login screen it BSOD'd, it rebooted and BSOD'd again, then after that I went to safemode and deleted all ATi graphics drivers again, and it booted into windows without the drivers.
So if I install the integrated graphics drivers the machine BSOD's, but I have no Idea what causes it.
System specs: CPU: AMD Athlon X4 635(not overclocked)
In safe mode it just installs a generic VESA driver I think, in any case you can boot in safe mode step by step and control the driver install to force it to use the generic VESA driver. You can also first disable the proprietary driver, then delete it, then restart windows without network connection, and it will only have the generic VESA driver to use the graphics card (when you get 1024*786 resultion, that's the generic VESA driver). Then you can install the driver you want by selecting a file instead of letting windows search for it online.
What I think the problem is, is that you can't really uninstall all Ati drivers through the normal windows GUI when the Ati card has already been removed, because the driver uninstall will go looking for the hardware. SInce you've sold it, you can't change that, but you can still remove the old drivers the hard way, by hacking the registry. It's not that hard to do, you just search for ATi, jump from search result to search result with F3, and delete the values that have anything to do with it, then you run Ccleaner to clean up the mess, and reboot, don't forget to first backup your registry. After reboot, I think the onboard graphics driver from the MSI site should work.
