Hello, i am currently trying to install windows 7 64 bits OS but for some reason when i provide the language, time zone currency & keyboard info the installer skips right to the screen where you select the drive where windows will be installed so i can't select a personalized installation thus, not being able to install windows 7 64 bits and only 32 bits, any help will be appreciated. I am trying to do this from a 4GB Kingston pendrive.
Hmmm sounds like your usb image might be borked, where'd you get it from?
also what did you use to make it?
Well, i got it from the pirate bay, since i had to use this pc as soon as possible i installed win7 32bits and it works pretty good. I used WinToFlash.
Oh Dear, don't do that. You can legally download it from here:
http://www.mydigitallife.info/windows-7-iso-x86-and-x64-official-direct-download-links-ultimate-professional-and-home-premium/
http://www.w7forums.com/official-windows-7-sp1-iso-image-downloads-t12325.html
and you can use this to install it to your usb drive
http://www.microsoftstore.com/store?Action=html&Locale=en_US&SiteID=msstore&pbPage=Help_Win7_usbdvd_dwnTool
Best of luck
Hey thanks a lot!
