So I just built my LAN pc and everything powers up just fine without the GPU. When I hook up the XFX 7970, I get the intial power but then the entire system just turns off? I have a nice Corsair 650 80+ bronze power supply so now I'm just a little confused. Any ideas why this is happening?
3570K
MSI Z77a-G41 Socket LGA 1155 ATX motherboard
Corsair HAF XB case.
What is an Ivy Bridge CPU doing on a Haswell motherboard :O
I might have the wrong motherboard posted, it boots just fine without the GPU on it. Loads everything.
So it's a Z77 OK :P
I can't think of anything. What I would do now is try booting with another GPU, any will do. Just so you can rule out the possibility that there's something wrong with the PCIe slot of the motherboard. When you ruled that out turn the GPU back for another one.
Hope you will fix your problem soon, good luck.
Edit: The voltage of that PSU is more than enough but there might of course also be the chance that there's something wrong with that component. If you have a spare one try replacing it.
When it comes to finding the cause of a problem like this one with a PC you can just replace the components till you find the culprit. There might be some compatibility issues I oversaw. Others might see something I didn't. I'll check again to be safe.
Thanks! It's so frustrating lol
are you plugging in the power connecters for the graphics card? like the 6 and 8 pin ones?
Yes, I plugged in two powercords into the gpu.
Try the GPU in another computer?
Really weird symptoms.
Any beeping or error codes that you can see/hear?
